Hello ,
my question is no matter how to configure the "Parity " bit on PC terminal , why received character is right ? on the MCU part , the parity is "none" .
And i have also test on K60 and K70, use the same PC terminal , the result is different : when i configure the Parity bit to "Odd" on PC termianal (the muc part still NONE),
when i send "hello world " from mcu , the character will like this :
so i think on K22 chip , this have some strange , any suggestion will be appreciate !
The attachment is the test project on frdm-k22 and twr-k60d100. KDS3.0 . without KSDK.
Thank!
I ran both projects. In both projects I sent the string "A" (0x41 0x00) without parity and I found that both MCUs send the same serial signal so I think that this is not a problem in the MCU.
FRDM-K22F
TWR-K60D100M
Earl.
