imx6q rel_imx_3.10.17_1.0.2_ga gplay fps=0
Question asked by pei xiuhui on May 27, 2015
Latest reply on Jun 17, 2015 by gusarambula
Hi, hello,When I use gplay play, FPS has been to 0, don't show, but a voice!Detailed information is as follows:
root@imx6qsabresd:~# gplay big_buck_bunny_1080p_h264.mov
playbin2 is employed!
fsl_player_init(): Successfully initialize!
fsl_player_set_media_location(): filename=big_buck_bunny_1080p_h264.mov
[Stopped  ][Vol=01][00:00:00/00:00:00][fps:0]Aiur: 3.0.11
Core: MPEG4PARSER_06.07.04  build on Dec  5 2013 11:41:38
  mime: video/quicktime; audio/x-m4a; application/x-3gp
  file: /usr/lib/imx-mm/parser/lib_mp4_parser_arm11_elinux.so.3.2
Content Info:
        URI:
              file:///home/root/big_buck_bunny_1080p_h264.mov
        Idx File:
              /home/root/.aiur/.home.root.big_buck_bunny_1080p_h264.mov.aidx
        Seekable  : Yes
        Size(byte): 725106140
Movie Info:
        Seekable  : Yes
        Live      : No
        Duration  : 0:09:56.46169mxc_vpu 2040000.vpu: vpu_open()
6000
        ReadMode  : Tramxc_vpu 2040000.vpu: size=0x4000, page no.=0x2040
ck
        Track     : 3
mxc_vpu 2040000.vpu: start=0x7392c000, pgoff=0x3c200, size=0x7c000
Track 00 [video_000000] Enabled
        Duration:mxc_vpu 2040000.vpu: [ALLOC] mem alloc size = 0x4fe807
0:09:56.458304000
        Language: und
        Mime:
              video/x-h264, parsed=(boolean)true, width=(int)1920, height=(int)1080, framerate
              =(fraction)24/1
[INFO]  Product Info: i.MX6Q/D/S
vpudec versiomxc_vpu 2040000.vpu: [ALLOC] mem alloc cpu_addr = 0xb5500000
ns
        plugin: 3.0.11mxc_vpu 2040000.vpu: start=0x73301000, pgoff=0x45500, size=0x4ff000
        wrapper: 1.0.46(VPUWRAPPER_ARM_LINUX Build on Apr 29 2015 15:42:10)
        vpulib: 5.4.23
        firmware: 3.1.1.46056
Track 01 [subtitle]: Disabled
        Codec: 0, SubCodec: 0
Track 02 [audio_000000] Enabled
        Duration: 0:09:56.480000000
        Language: und
        Mime:
              audio/mpeg, mpegversion=(int)4, channels=(int)6, rate=(int)48000, bitrate=(inmxcfb_ioctl
t)4
              48000, framxc_sdc_fb fb.23: Set color key to 0x00000818
med=(boolean)true, stream-format=(string)raw, codec_data=(buffer)11b0
FOUND GST_MESSAGE_TAG!
          codec: H.264/AVC
  language code: und
container format: MOV/MP4/3GP
    video codec: H.264/AVC
     frame rate: 24
    image width: 1920
   image height: 1080
          codec: AAC
  language code: und
        bitrate: 448000
MFW_GST_V4LSINK_PLUGIN 3.0.11 build on Apr 29 2015 21:10:59.
mxc_vpu 2040000.vpu: [ALLOC] mem alloc size = 0x94000
Beep: 3.0.11
Core: AAC decoder Wrapper  buimxc_vpu 2040000.vpu: [ALLOC] mem alloc cpu_addr = 0xac300000
ld on Jan 22 2014 15:42:53
  mimmxc_vpu 2040000.vpu: [ALLOC] mem alloc size = 0x5fa000
e: audio/mpeg, mpegversion=(int){2,4}
  file: /usr/lib/imx-mm/audio-codec/wrap/lib_aacd_wrap_arm12_elinux.so.3
CODEC: BLN_MAD-MMCODECS_AACD_ARM_03.07.00_CORTEX-A8  build on Sep 18 2013 10:29:53.
[INFO]  bitstreamMode 1, chromaInterleave 0, mapType 0, tiled2LinearEnable 0
number omxc_vpu 2040000.vpu: [ALLOC] mem alloc cpu_addr = 0xb5a00000
f channels: 6
sampling frequencymxc_vpu 2040000.vpu: start=0x70a06000, pgoff=0x45a00, size=0x5fa000
(Hz): 48000
    audio codec: AAC decoder
    image width: 1920
   image height: 1080
minimum bitrate: 360005
maximum bitrate: 360005
minimum bitrate: 354755
minimum bitrate: 345755
minimum bitrate: 343130
maximum bitrate: 375755
Fmxc_vpu 2040000.vpu: [ALLOC] mem alloc size = 0x2fd000
minimum bitrate: 341630
maximum bitrate: 387006
maximum bitrate: 429756
maximum bitrate: 431631
maximummxc_vpu 2040000.vpu: [ALLOC] mem alloc cpu_addr = 0xb6000000
bitrate: 437256
FOUND GST_MESSAmxc_vpu 2040000.vpu: start=0x6ff09000, pgoff=0x46000, size=0x2fd000
GE_TAG!
>>V4L_SINK: Actually buffer status:
        hardware buffer : 12
        software buffer : 0
maximum bitrate: 444006
maximumxc_vpu 2040000.vpu: [ALLOC] mem alloc cpu_addr = 0xb6300000
m bitrate: 458632
mxc_vpu 2040000.vpu: start=0x6fc0c000, pgoff=0x46300, size=0x2fd000
mxc_vpu 2040000.vpu: [ALLOC] mem alloc cpu_addr = 0xb6600000
mxc_vpu 2040000.vpu: start=0x6f90f000, pgoff=0x46600, size=0x2fd000
mxc_vpu 2040000.vpu: [ALLOC] mem alloc cpu_addr = 0xb6900000
mxc_vpu 2040000.vpu: start=0x6f612000, pgoff=0x46900, size=0x2fd000
mxc_vpu 2040000.vpu: [ALLOC] mem alloc cpu_addr = 0xb6c00000
mxc_vpu 2040000.vpu: start=0x6f315000, pgoff=0x46c00, size=0x2fd000
mxc_vpu 2040000.vpu: [ALLOC] mem alloc cpu_addr = 0xb6f00000
mxc_vpu 2040000.vpu: start=0x6f018000, pgoff=0x46f00, size=0x2fd000
mxc_vpu 2040000.vpu: [ALLOC] mem alloc cpu_addr = 0xb7200000
mxc_vpu 2040000.vpu: start=0x6ed1b000, pgoff=0x47200, size=0x2fd000
mxc_vpu 2040000.vpu: [ALLOC] mem alloc cpu_addr = 0xb7500000
mxc_vpu 2040000.vpu: start=0x6ea1e000, pgoff=0x47500, size=0x2fd000
mxc_vpu 2040000.vpu: [ALLOC] mem alloc cpu_addr = 0xb7800000
mxc_vpu 2040000.vpu: start=0x6e721000, pgoff=0x47800, size=0x2fd000
[Stopped  ][Vol=01][00:00:00/00:mxc_vpu 2040000.vpu: [ALLOC] mem alloc size = 0x2fd000
09:56][fps:0]mxc_vpu 2040000.vpu: [ALLOC] mem alloc cpu_addr = 0xb7b00000
mxc_vpu 2040000.vpu: start=0x6e424000, pgoff=0x47b00, size=0x2fd000
mxc_vpu 2040000.vpu: [ALLOC] mem alloc cpu_addr = 0xb7e00000
mxc_vpu 2040000.vpu: start=0x6e127000, pgoff=0x47e00, size=0x2fd000
mxc_vpu 2040000.vpu: [ALLOC] mem alloc cpu_addr = 0xb8100000
mxc_vpu 2040000.vpu: start=0x6de2a000, pgoff=0x48100, size=0x2fd000
mxc_vpu 2040000.vpu: vpu: memory phy:0x46000000 is phy memory
mxc_vpu 2040000.vpu: vpu: memory phy:0x461fe000 is phy memory
mxc_vpu 2040000.vpu: vpu: memory phy:0x4627d800 is phy memory
mxc_vpu 2040000.vpu: vpu: memory phy:0x46600000 is phy memory
mxc_vpu 2040000.vpu: vpu: memory phy:0x467fe000 is phy memory
mxc_vpu 2040000.vpu: vpu: memory phy:0x4687d800 is phy memory
mxc_vpu 2040000.vpu: vpu: memory phy:0x46c00000 is phy memory
mxc_vpu 2040000.vpu: vpu: memory phy:0x46dfe000 is phy memory
mxc_vpu 2040000.vpu: vpu: memory phy:0x46e7d800 is phy memory
mxc_vpu 2040000.vpu: vpu: memory phy:0x47200000 is phy memory
mxc_vpu 2040000.vpu: vpu: memory phy:0x473fe000 is phy memory
mxc_vpu 2040000.vpu: vpu: memory phy:0x4747d800 is phy memory
mxc_vpu 2040000.vpu: vpu: memory phy:0x47800000 is phy memory
mxc_vpu 2040000.vpu: vpu: memory phy:0x479fe000 is phy memory
mxc_vpu 2040000.vpu: vpu: memory phy:0x47a7d800 is phy memory
mxc_vpu 2040000.vpu: vpu: memory phy:0x47e00000 is phy memory
mxc_vpu 2040000.vpu: vpu: memory phy:0x47ffe000 is phy memory
mxc_vpu 2040000.vpu: vpu: memory phy:0x4807d800 is phy memory
get GST_MESSAGE_ELEMENT prepare-xwindow-id;
get GST_MESSAGE_ELEMENT playbin2-stream-changed, uri=(string)file:///home/root/big_buck_bunny_1080p_h264.mov;
FOUNDmxcfb_ioctl
GST_MESSAGE_TAG!
maximum bitratmxc_sdc_fb fb.23: Set global alpha of DISP3 BG - DI1 to 0
e: 466507
maximum bitrate: 470632
maximum bitrate: 523133
[Stopped  ][Vol=01][00:00:00/00:09:56][fps:0]Wait status change from 2 to 4
fsl_player_play()
FSL_PLAYER_01.00_LINUX build on Apr 29 2015 21:11:52
        [h]display the operation Help
        [p]Play
        [s]Stop
        [e]Seek
        [a]Pause when playing, play when paused
        [v]Volume
        [m]Switch to mute or not
        [>]Play next file
        [<]Play previous file
        [r]Switch to repeated mode or not
        [f]Set full screen or not
        [z]resize the width and height
        [t]Rotate
        [c]Setting play rate
        [i]Display the metadata
        [x]eXit
[Playing  ][Vol=01][00:00:07/00:09:56][fps:0]FOUND GST_MESSAGE_TAG!
maximum bitrate: 534008
[Playing  ][Vol=01][00:00:08/00:09:56][fps:0]FOUND GST_MESSAGE_TAG!
maximum bitrate: 543383
maximum bitrate: 548258
[Playing  ][Vol=01][00:00:15/00:09:56][fps:0]FOUND GST_MESSAGE_TAG!
maximum bitrate: 568133
[Playing  ][Vol=01][00:00:19/00:09:56][fps:0]FOUND GST_MESSAGE_TAG!
maximum bitrate: 614634
[Playing  ][Vol=01][00:00:42/00:09:56][fps:0]FOUND GST_MESSAGE_TAG!
maximum bitrate: 659260
[Playing  ][Vol=01][00:00:45/00:09:56][fps:0]FOUND GST_MESSAGE_TAG!
minimum bitrate: 340505
[Playing  ][Vol=01][00:00:53/00:09:56][fps:0]FOUND GST_MESSAGE_TAG!
maximum bitrate: 679510
maximum bitrate: 693010
[Playing  ][Vol=01][00:01:22/00:09:56][fps:0]FOUND GST_MESSAGE_TAG!
minimum bitrate: 334130
minimum bitrate: 330380
minimum bitrate: 327380
minimum bitrate: 322130
minimum bitrate: 321380
minimum bitrate: 319129
minimum bitrate: 310129
minimum bitrate: 295879
minimum bitrate: 295504
[Playing  ][Vol=01][00:03:51/00:09:56][fps:0]FOUND GST_MESSAGE_TAG!
maximum bitrate: 750761
[Playing  ][Vol=01][00:04:56/00:09:56][fps:0]FOUND GST_MESSAGE_TAG!
minimum bitrate: 290254
[Playing  ][Vol=01][00:04:57/00:09:56][fps:0]FOUND GST_MESSAGE_TAG!
minimum bitrate: 289879
Hope to get help,thank you.
