I am using FRDMKE06z Board and UART1 and UART2 is tested and working fine for LIN Protocol.
Right now for UART0 when I check at pin A2 and A3 I have tested and no transmission is fount to be happening.
SIM->PINSEL |= SIM_PINSEL_UART0PS_MASK;
I am seeing the register PINSEL is getting updated.
When checked with Oscilloscope I am getting Tx is always low.
Please let me know anything else i have to implement for using UART0.
Ajith Arikkath
UART0 clock is enabled and I am able to see the values in the register.
Is the pin having any Pull up.
Can you help on this.
Ajith Arikkath
Hello Ajith,
Have you enable the Transmitter ? here :
If also done , please show your code , or it hard to find your problem , thank !
Alice
Hi Ajith,
Does The UART0 clock been enable ?
