SH Card Code for K-20
moiz_husain
Hi I am Interfacing SD card with SPI in Kineties K-20.
how to write code for it any one can help with example for k-20
jeremyzhou
Hi Moiz,
I'd like to suggest that you'd better to choose the SDHC module for operating SD card instead of SPI interface.
FSL hasn't provided the similar demo to meet your requirement, however I'd like to share a post with you and I think it shows the way to make it.
please check the link as below.
Arduino Data-Logger Shield with the FRDM-KL25Z Board | MCU on Eclipse
Hope it helps.
Ping
