problems with MQX RTOS runing on my custom board.
Question asked by botao yang on May 25, 2015
Latest reply on May 27, 2015 by David E Seymour
I am using my own board based on MK60DN512VLL10,(use 50 MHZ external osc) the board can run projects without MQX.
I have cloned Board Support Packages based on TWRK60D100M, and use PE to change the MCU and clock settings, change the pins for the peripherals and GPIO, but the MQX still can't run on my board,
I want to know what else do I need to do to built my own MQX which can run on my board.
the picture below show the return message after i run the MQX  project , i think this will help you to find the problem.
