hello, since now I apologize for my english.
I'm on a project and i need to use the kl25z as vibration sensor.
i'v downloaded all the program, softwares and drive that I'v found, I'v get the vibration monitoring program to see the sensor, but when I press auto
to start the monitoring, I got an error.
I keep the usb por on sda port and my pc can read the com5 port as the kl25z.
there some one that could help me?
Hi alexandre colauto,
Do you mean you want to use KL25 as the control chip, and associate the external sensor and circuit to realize vibrate acquisition?
If yes, you need to refer to the external sensor and design the according code by yourself.
You said you get the vibration monitoring program, could you give us the program download link? and the KL25 board you are using?
Please give use more details.
Jingjing
