Hello everybody
Currently, I am undertaking a project about Electronic Control Unit for an electric vehicle and I want to programme the microcontroller unit in C language. I have more experience with assembler language and I would like to solve some doubts about C language in Freescale microcontrollers. For instance, if I have the following assembler code, how can I implement the subroutines in C language:
MOVB #$FF,PORTB
JSR Delay
MOVB #$00, PORTB
JSR Delay
Delay
LDAA #$FF
Delay_Loop
DECA
BEQ End_Delay
BRA Delay_Loop
End_Delay
RTS
I await your prompt response.
Good day
Solved! Go to Solution.
Here are some various example codes for S12XE line of MCUs.
When you open a project in CodeWarrior IDE and in the project open a source code file such as main.c, then mouse right click will show you a menu and there is option disassemble. This will allow you to see all C code in assembler language, so you can see how some functions are in C and assembler.
The particular assembler code you post is in C:
void Delay (void)
unsigned int i;
for(i=0; i<10000; i++)
asm nop;
asm nop;
asm nop;
void main (void)
PORTB = 0xFF;
Delay();
PORTB = 0x00;
Delay();
On the web you can find many C language tutorials and documents for learning programming language. But, still if you know assembler well, you can use it.
iggi
void Delay (void)
unsigned int i;
asm nop;
asm nop;
asm nop;
void main (void)
PORTB = 0xFF;
Delay();
PORTB = 0x00;
Delay();
iggi
Hello Iggi
Thanks for your response. Your information has been useful in my project, although I had to make the adjustment of time in the for structure. In several examples, I has seen each library has two indepent files, one with as *,c directory and the another as *.h directory. In this case, how can I create the delay library in my project.
On the other hand, I need to display information with a graphic LCD 128x64 Built-in controller ( S6B0108 ), do you know where can I find any library in order to manage this display?.
Best regars,
Anderson
