Hi expert,
When I test USB mouse feature, I found an USB error which will make the system die.
our platform is IMX6SL, and sw android version is 4.2.2.1.1
issue description:
1. power on the platform
2. plug in the USB mouse
3. plug out the USB mouse
4. do 2-3 loop
result: it will be 5%-10% rate to duplicate this issue on our different platforms.
And it seems happened when I plug out the mouse.
the critical log:
<7>[ 138.135729] hub 2-1:1.0: port 2: status 0507 change 0000
<7>[ 138.142644] hub 2-1:1.0: port 4: status 0503 change 0004
<7>[ 138.148523] fsl-ehci fsl-ehci.1: reused qh d462a9e0 schedule
<7>[ 138.154350] usb 2-1: link qh256-0001/d462a9e0 start 1 [1/0 us]
<7>[ 138.161020] hub 2-0:1.0: resume on port 1, status 0
<7>[ 138.166711] hub 2-1:1.0: state 7 ports 4 chg 0010 evt 0000
<7>[ 138.192236] usb 2-1.4: usb wakeup-resume
<7>[ 138.196738] usb 2-1.4: finish resume
<7>[ 138.200970] hub 2-1.4:1.0: hub_resume
<7>[ 138.206483] hub 2-1.4:1.0: port 3: status 0301 change 0001
<7>[ 138.322193] fsl-ehci fsl-ehci.1: reused qh d46a1360 schedule
<7>[ 138.328143] usb 2-1.4: link qh256-0001/d46a1360 start 3 [1/0 us]
<7>[ 138.334814] hub 2-1:1.0: resume on port 4, status 0
<7>[ 138.340240] hub 2-1:1.0: port 4, status 0503, change 0004, 480 Mb/s
<7>[ 138.347618] hub 2-1.4:1.0: state 7 ports 4 chg 0008 evt 0000
<7>[ 138.354221] hub 2-1.4:1.0: port 3, status 0301, change 0000, 1.5 Mb/s
<6>[ 138.432529] usb 2-1.4.3: new low speed USB device number 13 using fsl-ehci
<7>[ 138.544865] usb 2-1.4.3: skipped 1 descriptor after interface
<7>[ 138.550779] usb 2-1.4.3: udev 13, busnum 2, minor = 140
<6>[ 138.556790] usb 2-1.4.3: New USB device found, idVendor=413c, idProduct=3010
<6>[ 138.564805] usb 2-1.4.3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
<7>[ 138.575679] usb 2-1.4.3: usb_probe_device
<7>[ 138.579989] usb 2-1.4.3: configuration #1 chosen from 1 choice
<7>[ 138.586828] usb 2-1.4.3: adding 2-1.4.3:1.0 (config #1, interface 0)
<7>[ 138.595339] usbserial_generic 2-1.4.3:1.0: usb_probe_interface
<7>[ 138.601740] usbserial_generic 2-1.4.3:1.0: usb_probe_interface - got id
<7>[ 138.609376] usbhid 2-1.4.3:1.0: usb_probe_interface
<7>[ 138.615013] usbhid 2-1.4.3:1.0: usb_probe_interface - got id
<6>[ 138.626653] input: HID 413c:3010 as /devices/platform/fsl-ehci.1/usb2/2-1/2-1.4/2-1.4.3/2-1.4.3:1.0/input/input8
<7>[ 138.641362] usb 2-1.4.3: link qh8-0601/d09c1120 start 1 [1/2 us]
<6>[ 138.648757] generic-usb 0003:413C:3010.0006: input,hidraw0: USB HID v1.00 Mouse [HID 413c:3010] on usb-fsl-ehci.1-1.4.3/input0
<7>[ 138.661448] /home/jack/215pat/0evt0/imx6jb2/kernel_imx/drivers/usb/core/inode.c: creating file '013'
<7>[ 138.671794] hub 2-1.4:1.0: state 7 ports 4 chg 0000 evt 0008
<7>[ 138.682309] usb 2-1.4.3: unlink qh8-0601/d09c1120 start 1 [1/2 us]
<7>[ 138.752397] fsl-ehci fsl-ehci.1: reused qh d09c1120 schedule
<7>[ 138.758342] usb 2-1.4.3: link qh8-0601/d09c1120 start 1 [1/2 us]
<7>[ 141.727215] fsl-ehci fsl-ehci.1: detected XactErr len 0/4 retry 1
<7>[ 141.735151] usb 2-1.4.3: unlink qh8-0601/d09c1120 start 1 [1/2 us]
<7>[ 141.741661] hub 2-1.4:1.0: state 7 ports 4 chg 0000 evt 0008
<7>[ 141.748328] fsl-ehci fsl-ehci.1: detected XactErr len 0/8 retry 1
<7>[ 141.754690] fsl-ehci fsl-ehci.1: detected XactErr len 0/8 retry 2
<7>[ 141.761193] fsl-ehci fsl-ehci.1: detected XactErr len 0/8 retry 3
<7>[ 141.767566] fsl-ehci fsl-ehci.1: detected XactErr len 0/8 retry 4
<7>[ 141.774068] fsl-ehci fsl-ehci.1: detected XactErr len 0/8 retry 5
<7>[ 141.780389] hub 2-1.4:1.0: port 3, status 0100, change 0001, 12 Mb/s
<7>[ 141.780440] fsl-ehci fsl-ehci.1: detected XactErr len 0/8 retry 6
<7>[ 141.780563] fsl-ehci fsl-ehci.1: detected XactErr len 0/8 retry 7
<7>[ 141.780690] fsl-ehci fsl-ehci.1: detected XactErr len 0/8 retry 8
<7>[ 141.780814] fsl-ehci fsl-ehci.1: detected XactErr len 0/8 retry 9
<7>[ 141.780947] fsl-ehci fsl-ehci.1: detected XactErr len 0/8 retry 10
<7>[ 141.781065] fsl-ehci fsl-ehci.1: detected XactErr len 0/8 retry 11
<7>[ 141.781188] fsl-ehci fsl-ehci.1: detected XactErr len 0/8 retry 12
<7>[ 141.781312] fsl-ehci fsl-ehci.1: detected XactErr len 0/8 retry 13
<7>[ 141.781438] fsl-ehci fsl-ehci.1: detected XactErr len 0/8 retry 14
<7>[ 141.781563] fsl-ehci fsl-ehci.1: detected XactErr len 0/8 retry 15
<7>[ 141.781688] fsl-ehci fsl-ehci.1: detected XactErr len 0/8 retry 16
<7>[ 141.781813] fsl-ehci fsl-ehci.1: detected XactErr len 0/8 retry 17
<7>[ 141.781937] fsl-ehci fsl-ehci.1: detected XactErr len 0/8 retry 18
<7>[ 141.782062] fsl-ehci fsl-ehci.1: detected XactErr len 0/8 retry 19
<7>[ 141.782189] fsl-ehci fsl-ehci.1: detected XactErr len 0/8 retry 20
<7>[ 141.782311] fsl-ehci fsl-ehci.1: detected XactErr len 0/8 retry 21
<7>[ 141.782432] fsl-ehci fsl-ehci.1: detected XactErr len 0/8 retry 22
<7>[ 141.782556] fsl-ehci fsl-ehci.1: detected XactErr len 0/8 retry 23
<7>[ 141.782683] fsl-ehci fsl-ehci.1: detected XactErr len 0/8 retry 24
<7>[ 141.782806] fsl-ehci fsl-ehci.1: detected XactErr len 0/8 retry 25
<7>[ 141.782936] fsl-ehci fsl-ehci.1: detected XactErr len 0/8 retry 26
<7>[ 141.783057] fsl-ehci fsl-ehci.1: detected XactErr len 0/8 retry 27
<7>[ 141.783184] fsl-ehci fsl-ehci.1: detected XactErr len 0/8 retry 28
<7>[ 141.783311] fsl-ehci fsl-ehci.1: detected XactErr len 0/8 retry 29
<7>[ 141.783440] fsl-ehci fsl-ehci.1: detected XactErr len 0/8 retry 30
<7>[ 141.783564] fsl-ehci fsl-ehci.1: detected XactErr len 0/8 retry 31
<7>[ 141.783689] fsl-ehci fsl-ehci.1: devpath 1.4.3 ep0out 3strikes
<7>[ 141.783714] usb 2-1.4: clear tt buffer port 3, a13 ep0 t00080248
<7>[ 141.783853] fsl-ehci fsl-ehci.1: reused qh d09c1120 schedule
<7>[ 141.783879] usb 2-1.4.3: link qh8-0601/d09c1120 start 1 [1/2 us]
<3>[ 141.783947] generic-usb 0003:413C:3010.0006: can't reset device, fsl-ehci.1-1.4.3/input0, status -71
<7>[ 141.791213] fsl-ehci fsl-ehci.1: detected XactErr len 0/4 retry 1
Please help to check the attached FULL log.
Thanks!
BRs,
Jack
Hi Jack,
According with the log that you are getting and previous similar cases, it seems that it is a hardware issue (bad connections, defective cables, etc). Please take a look at the following thread from Freescale Community:
USB not enumerating devices correctly on i.MX280
On the following links you could also find helpful information regarding such behavior:
http://www.gossamer-threads.com/lists/linux/kernel/1528262
http://www.gossamer-threads.com/lists/linux/kernel/1363583
Hope this will be useful for you.
Best regards!
/Carlos
