how to set sdio clock on imx6q (Android)
stevenshi
hi Freescale:
     our board is designed base on SDB, and android os is 4.4.2.
     our wifi moudle use SDIO, the SDIO clock need 10~20M, i know the default SDIO Clock is 50M, so  we try to reduce the clock to 10~20M,  we change kernel_imx/arch/arm/mach-mx6/clock.c
static int _clk_usdhc3_set_rate(struct clk *clk, unsigned long rate)
    u32 reg, div;
    u32 parent_rate = clk_get_rate(clk->parent);
    div = parent_rate / rate;
    printk(KERN_ERR "++++++++++++++++++++++++++++++++++usdhc3 div is \n",div);
    if (div == 0)
        div++;
    if (((parent_rate / div) != rate) || (div > 8))
        return -EINVAL;
    reg = __raw_readl(MXC_CCM_CSCDR1);
    reg &= ~MXC_CCM_CSCDR1_USDHC3_PODF_MASK;
    reg |= (4 - 1) << MXC_CCM_CSCDR1_USDHC3_PODF_OFFSET;
    //reg |= (div - 1) << MXC_CCM_CSCDR1_USDHC3_PODF_OFFSET;
    __raw_writel(reg, MXC_CCM_CSCDR1);
    return 0;
this change is right???
Labels (6)
alejandrolozan1
That way the divisor will be hardcoded. I believe there must be other place in the code or configuration you could modify instead of that file.
Did that change work?
/Alejandro
