Can KDS 3.0.0 connect to the Eclipse Marketplace?
Question asked by Chad Williams on May 20, 2015
Latest reply on May 26, 2015 by Chad Williams
I have been attempting to use the Eclipse Marketplace to add plugins, but have so far been unsuccessful.
When I select Help>Eclipse Marketplace a dialog with progress bar is shown and it says
Retrieving data from http : // marketplace.eclipse.org
after about 40 seconds I receive the following error message:
Cannot open Eclipse Marketplace
Cannot install remote marketplace locations: Connection failed
This is most often caused by a problem with your internet connection. Please check your internet connection and retry.
Cannot complete request to http://marketplace.eclipse.org/catalogs/api/p: Unable to connect to repository http://marketplace.eclipse.org/catalogs/api/p
Connection timed out: connect
Connection failed
in the Eclipse error log it has a record:
Connection to http://marketplace.eclipse.org/catalogs/api/p failed on Connection timed out: connect. Retry attempt 0 started
I am running KDS on Windows 7 64 bit.
i have tried disabling, firewall and antivirus without success
I have also scoured the net for solutions and tried forcing Java to use IPv4 only as a possible solution by adding the line
-Djava.net.preferIPv4Stack=true to the kinetis-design-studio.ini file
I read that there is a Bug that may be related to my problem Bug 336477 – Error when connecting to Eclipse MarketPlace
Has anyone experienced this problem?
Is there a solution?
