Codewarrior Peoject To KDS
salah
Dear All,
I am using Codewarrior 10.6 for TWR-KW24D512 boards. I would like to try KDS instead codewarrior. How can I transfer code warrior project to KDS and configure the board? Please help
Thanks!
Salah
TICS_Fiona
To Import the project I did in KDS: File-> Import-> Existing Projects Into Workspace and then I selected the project I created in CodeWarrior. Once the project is imported I did right click on it and I selected "convert CodeWarrior project file."
For details you may refer to the documents below:
http://cache.freescale.com/files/microcontrollers/doc/user_guide/KDSPGQS.pdf
https://community.freescale.com/docs/DOC-102594
Hope it helps!
Fiona Kuang
Technical Information & Commercial Support
salah
Hi Fiona,
I just replied the SR with More information. Please take a look. I am still getting this error:
Description    Resource    Path    Location    Type
make: *** No rule to make target `MyWirelessApp Demo End Device - Security Enabled.elf', needed by `main-build'.  Stop.    MyWirelessApp Demo End Device - Security Enabled             C/C++ Problem
I am trying a demo which was generated using Beekit to CW.
Salah
