Hi community.
Desclibe on Vybrid Reference Manual, Rev.5 of 55.2.2 Features below.
・Blending of each pixel using up to 6 source layers dependent on size of panel
Question1
Does this sense would up 6 Layers that it can be blending simultaneously.
Or simultaneous blending Will to 6 pixels.
If 6 pixels.
Question2
What is six upper limit of the overlap of the frame buffer.
And ,In the same coordinates on the transparency (alpha value fully transparent), NOCOUNT is pixel.
Solved! Go to Solution.
I am not sure if I understand correctly the question. But you can blend up to 6 layers. And every pixel that overlaps to other will be taken care of.
Here you can find a training that explains the DCU module. In concept it applies to vybrid.
http://www.freescale.com/files/training/doc/dwf/DWF13_APF_AUT_T0500.pdf
I hope that helps.
/Alejandro
I hope that helps.
/Alejandro
