FXLC95000 FFT
Question asked by Majid Hamidi on May 15, 2015
Hi, I am working on FXLC95000 and trying to modify the example code  "GetAccelData" to implement 16 bit FFT analysis.
My program first stores 1024 data points in a global variable then calls FFT16 in the usertask, but it doesn't go through FFT (as attached).
I am guessing the problem is the allocated memory which is 4096 bytes for this task. Hoever, when I change that number in task setting,
the Coldfire still freezes when it reaches to FFT16 function call. Any idea?
Original Attachment has been moved to: GetAccelData_main.c.zip
