I want to calculate of ”Read freaquency calculations", "Max read frequency", "Hold timing"
takashitakahash
Hi community.
I'm trying to calculate the VYBRIDRSERIESEC_Rev_7.PDF p60 "Read freaquency calculations","Max read frequency","Hold timing", but I don't know following values
Would you please teach me  measured in each of the same kind of value .
・Flash access time
・flash_access(min)
・flash_data_valid(min)
alejandrolozan1
As far I as I see the timings you need are dependant on the QSPI memory you are using.
Therefore you will need to check the timings in your memory.
For example
Frequency calculator guideline (Max read frequency): SCK > (Flash access time)max + (Tis)max
Tis allowed for our QSPI module is a min of 4.5ns.  But Flash access time may be found in the manufacturer datasheet.
/Alejandro
alejandrolozan1
For example
/Alejandro
