First ofall you must install the Beekit which contains tools needed for generating a wireless project -
then you need do have codewarrior installed - note the Special edition is not enough - you must have a licensed version that are capable of compiling up to 60KB images.
When you have beekit installed then please have a look at the 802.15.4 MAC MyStarNetworkApp user's guide. (802154MSNAUG.pdf) which can be found in the installed beekit documentation folder.
this users guide describes how the MyStarNetwork application code is working.
To generate the MyStarNetwork app, you must start Beekit and create a project using the MyStartNetwork application templates.
BR,
Mads
