New installation CW10.6, casting errors (printf cant show negative values)
CarlFST60L
Senior Contributor II
Code snippet:
    printf("test result = %i\r\n", 0xFF);
    printf("test result = %i\r\n", (char)0xFF);
Simple code that I have run on my cygwin gcc, codepad.org and visual studio all return the expected result:
test result = 255
test result = -1
Run this code on my new MQX4.1.1 build with up to date CW10.6 (win7 64bit) and get:
test result = 255
test result = 255
Problem is this worked on my old windows build (also a fresh installation), so what changed? what setting could affect this?
Obviously I have dumbed this down but this is a serious probelm for my code which has been working on MQX4.1.1 up to date, and now has stopped (all i did was rebuild my computer and fresh install this).
DavidS
Hi Carl,
Weird.  I see it too.
Will report to the MQX Development team for them to look into.
Wondering if the default type casting of "char" has changed.
If I run your test with:
   printf("test result = %u\r\n", 0xFF);
   printf("test result = %d\r\n", (char)0xFF);
   printf("test result = %d\r\n", (signed char)0xFF);
I get on terminal this:
test result = 255
test result = 255
test result = -1
David
CarlFST60L
Its actually far worse for us. I have a project that that is around 512K and there are strange things happening with variables being passed to functions, and worse, when two variables are being cast and compared with each other the results are wrong.
