I tried to edit the start up .c but couldn't
Question asked by josephxavier on May 11, 2015
Latest reply on May 12, 2015 by josephxavier
for using malloc before mqxinit
proposed solution was to
Initialize the constructors from (in init_bsp.c), which MQX calls after it initializes the memory management component. is the solution that u proposed .
I tried to edit the start up .c but couldn't . eventhough I edited ,saved and build BSP ,PSP and project. while debugging it again goes to static initializer for cpp which I had commented . so could u share the steps to edit the startup.c in mqx project and bring it to effect .
I also tried to allocate static heap in linker, can this problem be over come by that method . can u share the steps while using fresscale compiler and ewl lib
