i.MX257 how to boot from NAND flash block1 when the NAND flash block0 was failed
Question asked by 王剑翰 on May 10, 2015
Latest reply on Jun 12, 2015 by igorpadykov
How to design i.MX257 can boot from Nand flash block1 when the Nand flash block0 was failed? We try to modify forcibly the ECC check value of block0 to illegal by ATK to simulate block0 failed, but the way is not usefull, i.mX257 also boot from Nand flash block0.
Could you help give me some good advice?
