I had made a small circuit with micro controller to generate pulses from 1 and 10 pulses per second. When circuit generates 1 pulse per second, it shall generate maximum of 10 pulses (i.e it shall generate for 10 seconds) and similarly when circuit generates 10 pulses per second and it shall generate the maximum of 500 pulses(i.e for 50 seconds). The result capturing is show in below table.
Header 1 | Header 2 | Header 3 |
Hz | F1 - (tin0 input) | Total Count |
1 | 2-4 | 26 |
10 | 23-24 | 1270 |
Please get me a solution on above problem.
You're not going to get a response to something that reads like a "school project".
The specification is incomplete anyway. Nobody could follow what you've written.
Tom
