Which pin configuration applies for MPXv4006DP?
yishi
In MPXv4006DP's datasheet, on Page 8, which pin configuration applies for product MPXv4006DP? "STYLE 1" or "STYLE 2"?
Thanks!
Tags (2)
TomasVaverka
Hi Yi,
The MPXV4006DP is an integrated pressure sensor with a single ended output, so Style 2 applies to this part.
Tomas
PS: If my answer helps to solve your question, please mark it as "Correct". Thank you.
