I'm using an IMX6Q 3.10.17.0 BSP.
Can freescale's Gstreamer 1.0 be ported to the 3.10.17 Kernel BSP?
My Gstreamer 0.10 doesn't have a videorate plugin. Is my base install broken?
Some of the element properties from tvsrc (ex. fps-n, do-timestamp do not work. Is my base install broken?)
Solved! Go to Solution.
HI Nathan
recommended to use latest BSP, it supports Gstreamer 1.0:
L3.14.28_1.0.0_iMX6QDLS_BUNDLE :
FSL BSP kernel 3.10.17 does not support Gstreamer 1.0,
one can refer to attached file, regarding porting suggest to look at
Problems building i.MX6 image for LinuxFB with Dizzy BSP
HI Nathan
I wish I could update the BST. Unfortunately we're well into development and running the update treadmill isn't appealing to us. Can you speak to any of my questions directly?
