codec configuration for IMX6SoloX board.
Question asked by robin singh on May 7, 2015
Latest reply on May 8, 2015 by Saurabh Patel
HI All,
I want to know the setting required for a new codec to make it work in imx6sx kernel 3.10.
here is what i am trying to do :
1) Connection :
LCD1_RESET -> AUD3_RXD   ->  -> I2S_SDIO  codec side
LCD1_ENABLE -> AUD3_TXC   -> J -> I2S_ LRCLK codec side
LCD1_HSYNC -> AUD3_TXD   ->  -> I2S_ SDI codec
LCD1_VSYNC -> AUD3_TXFS   ->  -> I2S_SCLK_codec
i have written a Machine driver(based on wm8962 driver   imx-wm8962.c) for my codec , but as of now i do not see any signal coming out:
Here is my DT binding:
/*DT binding for DAI LINK driver*/
        sound {
                compatible = "fsl,imx6q-sabresd-wm8962",
                           "fsl,imx-audio-mycodec";
                model = "mycodec-audio";
                cpu-dai = <&ssi2>; /* si-controller*/
                audio-codec = <&codec;
                audio-routing =
                        "Headphone Jack", "HPOUTL",
                        "Headphone Jack", "HPOUTR",
                        "Ext Spk", "SPKOUTL",
                        "Ext Spk", "SPKOUTR",
                        "AMIC", "MICBIAS",
                        "IN3R", "AMIC";
                mux-int-port = <2>;
                mux-ext-port = <3>;
                hp-det-gpios = <&gpio1 17 1>;
FIle : imx6sx.dtsi
audmux {
                 pinctrl_audmux_4: audmuxgrp-4 {
                        fsl,pins = <
                                MX6SX_PAD_LCD1_ENABLE__AUDMUX_AUD3_TXC  0x130B0
                                MX6SX_PAD_LCD1_VSYNC__AUDMUX_AUD3_TXFS  0x130B0
                                MX6SX_PAD_LCD1_HSYNC__AUDMUX_AUD3_TXD    0x120B0
                                MX6SX_PAD_LCD1_RESET__AUDMUX_AUD3_RXD    0x130B0
File : imx6sx-sdb.dts
&audmux {
        pinctrl-names = "default";
        pinctrl-0 = <&pinctrl_audmux_4>;
        status = "okay";
I am using SSI2 ===>  AUD3 ====> my codec
Does above setting looks fine or i am missing something? please  share some details including clock for ssi2 etc
thanks
Robin Singh
