psptypes.h: No such file or directory
oaf
I'm trying to compile the MSD_CDC project from KSDK-1.2.0 with KDS-3.0.0 and it will not compile:
c:\freescale\ksdk_1.2.0\rtos\mqx\mqx\source\include\mqx.h:82:22: fatal error: psptypes.h: No such file or directory
Tags (3)
oaf
I don't quite understand what the problem is, but my feeling is that the project-control system in KDS is very fragile.
When delete the project and try again the problem is gone. It's a little bit frightening that the import of projects seems
to be not 100% each time.
ivadorazinova
Hello Ole Asbjorn Fadum,
please, just for information did you compile your project with all these libraries?
<install_dir>/rtos/mqx/mqx/build/<tool_chain>/mqx_<board>
<install_dir>/rtos/mqx/mqx_stdlib/build/<tool_chain>/mqx_stdlib_<board>
<install_dir>/usb/usb_core/host/build/<tool_chain>/usbh_sdk_<board>_mqx
<install_dir>/lib/ksdk_mqx_lib/<tool_chain>/<platform>
Did you follow all of these steps in attachment ?
Thank you for your feedback!
Iva
oaf
I was just following the example .pdf and manually made what I thought was the necessary libraries.
Today I've tried to import 'Existing Projects Set'
    1. ...KSDK\V_1.2.0\rtos\mqx\build\kds\workspace_frdmk64f\build_libs.wsd
    2. ...\KSDK\V_1.2.0\examples\frdmk64f\demo_apps\usb\device\composite\msd_cdc\mqx\kds\dev_msd_cdc_frdmk64f_mqx.wsd
The 2nd import warns that:
    mqx_frdmk64f_all does not exists
    mqx_stdlib_frdmk64f_all does not exists
After enable USB-Composite
    ,,,\KSDK\V_1.2.0\usb\usb_core\device\include\frdmk64f\usb_device_config.h
The build-all worked just fine.
The Segger debug setup was incorrect but when looking on an other project I was able to get it work.
ivadorazinova
Hi Ole Asbjorn Fadum,
I tested whole procedure on my side and it was compiled without problems on my side.
First I imported the project, then I imported the libraries.
When I go to J-link Debug mode, K64F is set.
Do you have the same screen for Debug Configurations?
Please, describe your problem more detail.
Iva
