Resolution modification in decoder
ramakrishnakama
When we play video using mfw_wmvdecoder, video resolution getting changed.
Actual video resolution is 320 X 240. But decoder output resolution is 384 X 304.
Because of this setting video property not proper and video not getting played in
middle of the screen.
gst-lauch-0.10 filesrc location=/mnt/usb/320x240_WMV7_WMA7.asf typefind=true !
aiurdemux name=demux demux. ! queue ! mfw_wmvdecoder ! mfw_v4lsink -v
We can see change in resolution of in output of deocder.
Video property of the video we are using for testing is as follows :
Topology:
container: Advanced Streaming Format (ASF)
audio: Windows Media Audio 7
video: Windows Media Video 7
Properties:
Duration: 0:01:53.791000000
Seekable: yes
Tags:
container format: ASF
video codec: Microsoft Windows Media 7
audio codec: WMA Version 7
We are using gst-fsl-plugins version 3.5.7 and gstreamer version 10.36
Result of "uname -a" is
Linux freescale 3.0.35-2154-g94689e1 #180 SMP PREEMPT Wed Mar 4 15:24:49
CST 2015 armv7l GNU/Linux
BSP version is 3.0.35 based customized BSP.
Board is IM6D based customized board .
This is very urgent, for a production program. SOP is very close.
Please help us analysing this ASAP.
Thanks and Regards:
Ramakrishna Kamath
jack_mao
Hi Ramakrishna kamath,
       I got the video clip and the detail description, from the description, your engineer  meet two width/height values for the video size, both of them are not the correct width/height, the demux return value only indicate that the container size setting, this value could be incorrect, the 384x304, 1920x1088 is also not the video size, it 's only used to allocate bigger memory for vpu,  you should use the VUP decoder returned value for your counting.
best regards
Jack
ramakrishnakama
Hi Jack,
Vpudec doesn't support WMV1 and WMV2.
How can we get resolution values from DECODER?
Please help us to fix this issue.
Thanks and Regards,
Ramakrishna Kamath.
jack_mao
Hi Ramakrishna Kamath,
      For ms decoder I don't know if you use our decoder or open source decoder , if it's our decoder, there is decoder header file, init API will parser the sequence header and return thr resolution value. If you use open source, you have to find it by yourself.
best regards
Jack
jack_mao
Hi ramakrishnakamath,
    Please share the video to us, that will be helpful for us to debug this issue.
best regards
Jack
ramakrishnakama
Hi Junping Mao
I have uploaded video in https://community.freescale.com/videos/3268.
Ramakrishna Kamath
jack_mao
      I can't access the link, seems there is right limitation, could you use transweb? or any other method?
best regards
Mao junping
ramakrishnakama
Please share mail id, I'll share video with you, or Please give me transweb link where i can upload video.
Thanks and Regards,
Ramakrishna Kamath
jack_mao
best regards
jack
jack_mao
    I still have no right to access your video link https://community.freescale.com/videos/3268
best regards
Jack
ramakrishnakama
Thanks and Regards,
Ramakrishna Kamath
jack_mao
      Transweb is a intenal site which customer transfer file to freescale http://transweb.freescale.net, but you need a account to login, I'm not sure you could access it, is there any cloud site which can put your file on it then I can download?
best regards
Jack
ramakrishnakama
Can you access file from  Welcome to Freescale Semiconductor
Thanks and Regards,
Ramakrishna Kamath
jack_mao
    I can't access this site, it's for external user, we have internel site as mentioned in my reply to access the tranfered file, you could try if you can access from the external link.
best regards
Jack
ramakrishnakama
Hi Junping Mao,
I don't have access to internal site. How can i send file. I have transferred file to 1-3720719951 SR Number. Can you get it from there?
ramakrishnakama
Hi Junping Mao,
Please let me know how can i send files. Is there any other way to send a file?
Thanks and Regards,
Ramakrishna kamath
jack_mao
    Please find a free net disk to upload  your video clip, then tell me to download. Thanks!
best regards
Mao junping
