I have created an MSD component, with DbgCs, on the FRDM-K22F board, which appears to be working fine, but I am unable to get any output on the DbgCs from any of the MSD instances of USB_PRINTF or my own.
My project archive can be found at:
https://dl.dropboxusercontent.com/u/49100658/FRDM-K22F.zip
Any help would be appreciated.
DaR
Solved! Go to Solution.
Getting back to this, Kan_Li came up with a solution, requiring a KDS update, but a solution, none the less:
https://community.freescale.com/docs/DOC-105714
DaR
DaR
hI DaR,
I may suggest you check if this thread can help:
https://community.freescale.com/message/477111#477111
Zhang Jun
ZhangJennie,
While that article suggests using USB_PRINTF, it does not appear to address anything about debugging those usages, and just assumes that it works.
I have all sorts of instances where USB_PRINTF is used, but so far, none appear to work for me.
Thanks for the suggestion though.
DaR
ZhangJennie,
DaR
