The leakage current of MMPF0100 RESETBMCU.
satoshishimoda
Senior Contributor I
Hi community,
Our partner have a question about MMPF0100
They want to know the leakage current of MMPF0100 RESETBMCU when it is Hi-Z.
Would you let us know it?
Satoshi Shimoda
Tags (2)
HI Satoshi
all available data is provided in MMPF0100 datasheet.
Sorry, other data is not available.
Hi Satoshi
RESETBMCU is open drain output, so leakage drawn
is defined by pull-up resistor, which should be used for such case.
satoshishimoda
Hi Igor,
I found there is leakage current as following even though it is open drain.
Open collector - Wikipedia, the free encyclopedia
And our partner thinks the leakage should be defined similar as the following chip.
http://toshiba.semicon-storage.com/info/docget.jsp?did=7336&prodName=TC74HC04AP
Satoshi Shimoda
HI Satoshi
