T4240, can't burn flash from u-boot. Any suggestions?
Question asked by R D on Apr 30, 2015
We can burn flash all day long using CodeWarrior, but we are unable to program from u-boot. Any thoughts on where to start debuging this issue?
We can do read device ID commands with no problem (see attached snapshot; that's a valid Intel ID) , meaning write/read activity from the u-boot command prompt are responding so I was wondering if there is any particular feature in the CW flash access which is different from u-boot (other than the CFI commands being misaligned) so with that in mind I was wondering if anyone could share the .tcl scripts found in the bring-up documentation "Board Bringup Using CodeWarrior"? Thinking this is somewhere to start looking into this.
(erase_sector and write_flash) so I can run a sanity check. Perhaps it's a x8 vs. x16 address alignment don't know yet.
I am thinking of continuing to look at the flash CFI structure to see if we are doing anything out of the ordinary.
I appreciate your help.
Thanks.
Original Attachment has been moved to: teraterm.log.zip
Original Attachment has been moved to: UBOOT.txt.zip
