MKL25Z32VFM4 IC  not working properly
Question asked by Prakask Nair on Apr 30, 2015
Latest reply on Jul 5, 2015 by jeremyzhou
I am using a MKL25Z32VFM4 IC which is in 32 pin QFN package on PCB designed for my project.
The problem is that, i am getting 1 Volt on VOUT33 pin (no 5) and reset pin (no. 19), whereas I should be getting 3.3 Volts on both.
I have already connected a pull up of 10k on reset pin,
checked the VDD and VSS and they are perfect.
I request all to suggest me the possible cause for this behavior and the remedy
