MC56F8002 interrupt reset MCU
Question asked by Jean-Francois Lemire on Apr 29, 2015
Latest reply on Apr 29, 2015 by Jean-Francois Lemire
Code warrior 8.3.
I started a projet on MC56F8002 based on an old code. With the new silicon revision, the MCU is not working properly. After a debugging session, I realized that the MCU reset when an interrupt occurs. If I don't activate interrupts, the MCU do not reset. Here is the line to enable the interrupt __EI(0);. On the old silicon revision (mask 1M53M) there is no problem with interrupts.
Any suggestion?
JF
