having difficulties comunicating via BDM
arshagminelian
Hi There
we're having difficulties comunicating via BDM with:
KIT912S812ECUEVM Small Engine Reference Design Featuring the MM912_S812 MCU and Ignition/Injector Driver System-in-Package
iggi
Do you use OSBDM on board or external programmer (which one)?
What CodeWarrior version do you use?
What Windows version do you use (XP, 7, 32-bit, 64-bit )?
Can you describe the difficulties you are having more in details?
