'AS1_SendBlock' makes integer from pointer without a cast --- warning
Question asked by Russell Sher on Apr 24, 2015
Latest reply on Apr 26, 2015 by Russell Sher
I am using processor expert to make a uart as below:
int main(void)
  char OutData[] = "Hello world";
  LDD_TError Error;
  LDD_TDeviceData *MySerialPtr;
  /*** Processor Expert internal initialization. DON'T REMOVE THIS CODE!!! ***/
  PE_low_level_init();
  /*** End of Processor Expert internal initialization.                    ***/
  /* Write your code here */
  for(;;)
   Set_Led_SetVal();  // Led on
   AS1_SendChar('A'); // Send a Char
   Error = AS1_SendBlock(MySerialPtr, OutData, sizeof(OutData)); /* Send block of characters */
I get this warning:
passing argument 2 of 'AS1_SendBlock' makes integer from pointer without a cast [enabled by default]
passing argument 3 of 'AS1_SendBlock' makes pointer from integer without a cast [enabled by default]
I'm not quite sure what I should change, any advice?
thanks
Russell
