Valt on fsl_adc KSDK (Voltage reference module for KSDK?)
holyhope
Hi to all,
I'm developing with KSDK 1.1.0, KDS 2.0.0 on K20 up with KSDK (using K60 uP inside KSDK)
Developing and debugging some problem on adc I want try to use the internal Vref for ADC instead my external reference.
I set to PEx "Valt" in "reference voltage" but I can't set o modify the Alternate Voltage.
I not see any KSDK Voltage Reference componente.
What I can do to modify my Valt ? So I can use that in fsl_adc component...
Massimiliano
kerryzhou
Hi Massimiliano Sturla,
      Please tell me the full name of your K20.
Jingjing
