Multichannel ATD in mc9s12xep100
mrunaljoshi
Hi !
I am working on the Demoboard for MC9S12XEP100 . I need 3 atd channels for my project but the results of conversion for all three seem to be getting stored in ATD0DR0 i.e the result register for channel 0 only. I have tried the sequence storage of the results but doesnt seem to work .  Can someone please help ?
ZhangJennie
Hi Mrunal,
I wonder you didn't select the correct channel before getting value from ATD.
for example, to get the correct value from channel 1, we need:
/* Run measurement of channel 1 with set wait for result */
    err = AD2_MeasureChan(TRUE,1U);
    /* Get result of channel 1 justified to left*/
    err = AD2_GetChanValue16(1U,&Value1);
I suggest you check sample code under
{CW5.1 install folder}\ProcessorExpert\Projects\Test projects\ADC
can this help?
Zhang Jun
