Error found after trying to download program in to mpc5634m
mootan
I'm trying to download program using the program cw_progppcnexus.exe that you recommend but i encounter "Cannot enter background mode.
TICS_Fiona
Are you using TRK-MPC5634M? Or the board designed by yourself? Are you program with P&E USB multilink or OSJTAG?
For using TRK-MPC5634M, first, please check how the J1 and J5 jumpers are set on TRKMPC5604B. if SBC_5V is selected then J5 (Vsup) should be closed to enter SBC chip into debug state.
If the issue still exists, try to uninstall the P&E USB multilink or OSJTAG drivers, then reinstall it.
Fiona Kuang
Technical Information & Commercial Support
TICS_Fiona
Fiona Kuang
