help: imx6solo wm8960始终没有声音输出
yingcaitan
我尝试各种办法,wm8960始终不能得到声音输出。调试过程如下:
首先,打开电源使能脚:
       ret=gpio_request(SABRESD_CODEC_PWR_EN, "audio_pwr_en");
       if (!ret){
              printk("Turn on audio(wm8962) power!(1:enable)\n");
              gpio_direction_output(SABRESD_CODEC_PWR_EN, 1);         // 0:enable, 1:disable
              gpio_free(SABRESD_CODEC_PWR_EN);
串口打印如下出错信息:
wm8962 0-001a: Failed to get supply 'SPKVDD1': -19
wm8962 0-001a: Failed to request supplies: -19
wm8962 0-001a: asoc: failed to probe CODEC wm8962.0-001a: -19
asoc: failed to instantiate card wm8962-audio: -19
Initialize HDMI-audio failed. Load HDMI-video first!
ALSA device list:
  No soundcards found.
imx6q_init_audio();后移几行,上面的错误就没有了。但出现下面错误
wm8962 0-001a: Device is not a WM8962, ID 0 != 6243
wm8962 0-001a: asoc: failed to probe CODEC wm8962.0-001a: -22
asoc: failed to instantiate card wm8962-audio: -22
sound/soc/codec/下面的wm8962.c改用wm8960.c(修改KconfigMakefile)。
wm8960_i2c_probe不调用。原因是:
       .driver = {
              .name = "wm8960",
              I2C_BOARD_INFO("wm8962", 0x1a),
              .platform_data = &wm8962_config_data,
linux driver是根据name来匹配的,如果匹配就调用。
登记了snd_soc_register_codec后,codecprobe也不调用。
原因是下面这个snd_dai_drivername要一致才能调用。
static struct snd_soc_dai_driver wm8960_dai = {
       .name = "wm8960",
static struct snd_soc_dai_link imx_dai[] = {
              .name = "HiFi",
              .stream_name = "HiFi",
              .codec_dai_name       = "wm8960",
调用后显示:
wm8960 0-001a: wm8960 probed success!
wm8960 0-001a: Failed to add route HPOUTL->Headphone Jack
asoc: wm8960 <-> imx-ssi.1 mapping ok
input: wm8960-audio DMIC as /devices/platform/soc-audio.5/sound/card0/input1
input: wm8960-audio Ext Spk as /devices/platform/soc-audio.5/sound/card0/input2
ALSA device list:
  #0: wm8960-audio
root@imx6solo ~$ find / -name *wm8960*
/sys/devices/platform/imx-wm8960.0
/sys/bus/platform/devices/imx-wm8960.0
/sys/bus/platform/drivers/imx-wm8960
/sys/bus/platform/drivers/imx-wm8960/imx-wm8960.0
/sys/bus/i2c/drivers/wm8960
/proc/asound/wm8960audio
root@imx6solo ~$
问题是/dev/下面并没有增加设备,无法使用/dev/pcm
root@imx6solo /usr/bin$ aplay -L
null
    Discard all samples (playback) or generate zero samples (capture)
root@imx6solo /usr/bin$ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: wm8960audio [wm8960-audio], device 0: HiFi wm8960-0 []
  Subdevices: 1/1
  Subdevice #0: subdevice #0
现在应该是试试ALSA驱动程序是不是真能用的时候了. 接者就是使用它.
查看声卡是否存在:
root@imx6solo ~$ cat /proc/asound/cards
0 [wm8960audio    ]: wm8960-audio - wm8960-audio
                      wm8960-audio
ALSA 驱动程序在 /dev/snd/ 目录下有自己的驱动程序。
root@imx6solo ~$ ls /dev/snd/
controlC0 pcmC0D0c   pcmC0D0p timer
http://www.alsa-project.org/main/index.php/Download上面下载alsa tester包括alsa-lib, alsa-utils
编译:./gitcompile CC=arm-linux-gcc --host=arm-linux
现在进化到configure都从网络上临时下载的地步了,我有点out了。
编译alsa-utils总是过不去。重新下载alsaplayer
./configure --host=arm-linux CC=arm-linux-gcc --disable-oggvorbis
然后make.
对比了wm8960.c/wm8962.c, imx-wm8960.c/imx-wm8962.c,差别其实非常大。
http://bbs.21ic.com/forum.php?mod=viewthread&tid=869393,从这个链接地址可以下载imx-wm8960.c
重新配置linux kernel,设备/dev/dsp/dev/mixer出来,这是OSS接口的要求。
root@imx6solo /test/audio$ ./wavplay test.wav
File Magic:         [RIFF]
File Length:        [424636]
File Type:          [WAVE]
Fmt Magic:          [fmt ]
Fmt Size:           [16]
Fmt Format:         [PCM]
Fmt Channels:       [2]
Fmt Sample_rate:    [22050](HZ)22khz
Fmt Bytes_p_second: [88200]
Fmt Blocks_align:   [4]
Fmt Sample_length:  [16]
Chunk Type:         [data]
Chunk Length:       [424600]
Plug PCM: Rate conversion PCM (44100, sformat=S16_LE)
Converter: linear-interpolation
Protocol version: 10002
Its setup is:
  stream : PLAYBACK
  access : RW_INTERLEAVED
  format : S16_LE
  subformat : STD
  channels : 2
  rate : 22050
  exact rate : 22050 (22050/1)
  msbits : 16
  buffer_size : 8192
  period_size : 256
  period_time : 11609
  tstamp_mode : NONE
  period_step : 1
  avail_min : 256
  period_event : 0
  start_threshold  : 1
  stop_threshold   : 8192
  silence_threshold: 0
  silence_size : 0
  boundary : 536870912
Slave: Direct Stream Mixing PCM
Its setup is:
  stream : PLAYBACK
  access : MMAP_INTERLEAVED
  format : S16_LE
  subformat : STD
  channels : 2
  rate : 44100         //44khz
  exact rate : 44100 (44100/1)
  msbits : 16
  buffer_size : 16384
  period_size : 512
  period_time : 11609
  tstamp_mode : NONE
  period_step : 1
  avail_min : 512
  period_event : 0
  start_threshold  : 2
  stop_threshold   : 16384
  silence_size : 0
  boundary : 1073741824
Hardware PCM card 0 'wm8960-audio' device 0 subdevice 0
Its setup is:
  stream : PLAYBACK
  format : S16_LE
  subformat : STD
  channels : 2
  msbits : 16
  buffer_size : 16384
  period_size : 512
  period_time : 11609
  tstamp_mode : ENABLE
  period_step : 1
  avail_min : 512
  period_event : 0
  start_threshold  : 1
  stop_threshold   : 1073741824
  silence_size : 1073741824
  appl_ptr : 0
  hw_ptr : 0
root@imx6solo /test/audio$ aplay test.wav
Playing WAVE 'test.wav' : Signed 16 bit Little Endian, Rate 22050 Hz, Stereo
Aborted by signal Interrupt...
仍然是没有声音输出!!
换了一个44khz采集率的wav文件,仍然没有声音输出!
root@imx6solo /test/audio$ aplay xihuanni.wav
Playing WAVE 'xihuanni.wav' : Signed 16 bit Little Endian, Rate 44100 Hz, Stereo
再次检查了pin mux config,是正确的。但就是没有任何audio输出!
如果直接用imx-wm8962.c,则有许多出错信息,如下:
WM8960 PLL: Unsupported N=3
Failed to start FLL: -22
Failed to set SYSCLK: -22
asoc: machine hw_params failed
ALSA lib pcm_direct.c:980:(snd1_pFailed to set SYSCLK: -22
cm_direct_initialize_slave) unable to install hw params
ALSA lib pcm_dmix.c:1030:(snd_pcm_dmix_open) unable to initialize slave
aplay: main:660: audio open error: Invalid argument
所以,要用imx-wm8962.c来修改的话,还有点麻烦,不会很容易。
网上找了一个人交流,他用的是imx-wm8960.module,就是编译出来的.o
ifneq ($(wildcard sound/soc/imx/imx-wm8960.c),)
snd-soc-imx-wm8960-objs := imx-wm8960.c
else
snd-soc-imx-wm8960-objs := imx-wm8960.module
endif
我这样修改后,运行导致crash
register wm8960 I2C driver success!
Unable to handle kernel paging request at virtual address f8f2fe18
pgd = 80004000
[f8f2fe18] *pgd=1bce9811, *pte=00000000, *ppte=00000000
Internal error: Oops: 807 [#1] PREEMPT
Modules linked in:
CPU: 0    Not tainted (3.0.101-2790-gc248ed7 #274)
Tags (2)
Rita_Wang
Hi yingcai Tan,
Which version of BSP are you using?
Have a great day
Dan
yingcaitan
L3.0.101_4.1.1_141016_source, cpu is imx6solo
yingcaitan
最新进展: 先验证了i2c,示波器显示有输出,并且测了看device addr也是0x1A
alsamixer配置也是全部拉高,退出后重新进入,也是对的,可以保存和读出。
i2s data仍然没有,数据线对地电阻也测了,并没有短路。
jimmychan
e.g. if you using AUD3 pins (TXC, TXFS, TXD, RXD...) , make sure the IOMUX setting properly in the your_board.c file.
Also, please check the AUD3 PAD setting is properly in the linux/arch/arm/plat-mxc/include/mach/iomux-mx6dl.h.
For example: if the PAD setting is NO_PAD_CTRL for the pins, please change it to MX6DL_ADU_PAD_CTRL.
#define MX6DL_PAD_CSI0_DAT5__AUDMUX_AUD3_TXD                                  \
        IOMUX_PAD(0x038C, 0x0078, 4, 0x0000, 0, NO_PAD_CTRL)
change to :
        IOMUX_PAD(0x038C, 0x0078, 4, 0x0000, 0, MX6DL_ADU_PAD_CTRL)
yingcaitan
I double checked, see below:
#define MX6DL_PAD_CSI0_DAT7__AUDMUX_AUD3_RXD                               \
IOMUX_PAD(0x0394, 0x0080, 4, 0x0000, 0, MX6DL_ADU_PAD_CTRL)
#define MX6DL_PAD_CSI0_DAT6__AUDMUX_AUD3_TXFS                              \
   IOMUX_PAD(0x0390, 0x007C, 4, 0x0000, 0, MX6DL_ADU_PAD_CTRL)
Still no audio out.
More info:
snd_pcm_dmix_open()
imx_ssi_startup
snd1_pcm_hw_open_fd()
imx_ssi_set_dai_fmt,ret=0
*** sample_rate = 44100, bclk = 24000000, sysclk = 11289600
imx_ssi_hw_params
snd_imx_pcm_mmap,ret=0
imx_ssi_trigger,ret=0
snd_pcm_plug_open()
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
Aborted by signal Interrupt...imx_ssi_trigger,ret=0
imx_ssi_shutdown
jimmychan
is there any signal output from the AUDMUX pins? could you show me the part of schematic how you connect the wm8960?
yingcaitan
pls check attachment.
在 2015-04-23 16:19:39,jimmychan <admin@community.freescale.com> 写道:
Re: help: imx6solo wm8960始终没有声音输出
reply from jimmychan in i.MX Community - View the full discussion
Did your question get answered? If so, say thanks by clicking Correct Answer in the community thread!
Reply to this message by replying to this email, or go to the message on Freescale Community
Start a new discussion in i.MX Community by email or at Freescale Community
Following Re: help: imx6solo wm8960始终没有声音输出 in these streams: Inbox
yingcaitan
我怀疑是软件原因:
static int imx_ssi_probe(struct platform_device *pdev)中,
       ret = snd_soc_register_dai(&pdev->dev, dai);
       if (ret) {
              dev_err(&pdev->dev, "register DAI failed\n");
              goto failed_register;
而在static __devinit int wm8960_i2c_probe(struct i2c_client *i2c,
                                  const struct i2c_device_id *id)中,
       ret = snd_soc_register_codec(&i2c->dev,
                     &soc_codec_dev_wm8960, &wm8960_dai, 0);
Registered DAI 'wm8960-hifi'
Registered DAI 'imx-ssi.1'
设置audio参数时,imx_hifi_hw_params()中调用的是wm8960-hifiDAI驱动。
现在的问题是SSIimx_ssi_set_dai_sysclk()imx_ssi_set_dai_sysclk()都无法调用,我不知道这是否是SSIBCLK无信号的原因。
jimmychan
Please check if you are mapping the Speaker with dapm widget correctly. For example, in the imx_wm8962_init, there are Headphone and AMIC. And there are some codes are checking the hp_gpio which is the Headphone Detect gpio pin. But in your schematic, you don't use the headphone. So, please check your driver code, the speaker may not map correctly.
yingcaitan
I've masked the detect pin already. I put code here.
static int mxc_wm8962_init(void)
int rate;
clko = clk_get(NULL, "clko_clk");
if (IS_ERR(clko)) {
pr_err("can't get CLKO clock.\n");
return PTR_ERR(clko);
/* both audio codec and comera use CLKO clk*/
rate = clk_round_rate(clko, 24000000);
clk_set_rate(clko, rate);
wm8962_data.sysclk = rate;
return 0;
static struct mxc_audio_platform_data wm8962_data = {
.ssi_num = 1,
.src_port = 2,
.ext_port = 3,
// .hp_gpio = SABRESD_HEADPHONE_DET,
.hp_active_low = 1,
// .mic_gpio = SABRESD_MICROPHONE_DET,
.mic_active_low = 1,
.init = mxc_wm8962_init,
.clock_enable = wm8962_clk_enable,
在 2015-04-24 13:37:36,jimmychan <admin@community.freescale.com> 写道:
Following help: imx6solo wm8960始终没有声音输出 in these streams: Inbox
jimmychan
I mean in the sound/soc/imx/imx-wm8962.c , not the board-mx6q_sabresd.c.
You can find the "plat->hp_gpio" in the code.
and the "if (plat->hp_gpio != -1)"
So, if you comment out the hp_gpio in board-mx6q_sabresd.c, then hp_gpio become -1, that may be the problem.
yingcaitan
And could you kindly provide me imx-wm8960.c ? thanks.
在 2015-04-24 14:30:35,jimmychan <admin@community.freescale.com> 写道:
jimmychan
sorry, I don't have imx-wm8960.c.
please check in your driver code, please try to add the widget and audio_map for the speaker. And enable the speaker in the imx_wm8960_init.
For reference,
how to set audio path routing
yingcaitan
But I use imx-wm8960.c which does not check plat->hp_gpio
jimmychan
Please check this:
https://community.freescale.com/message/332170#332170
please double check the IOMUX setting that is match with your own hardware design.
