LCD Rotate Display 180 Degrees
Question asked by carlo val gocela on Apr 20, 2015
Latest reply on Apr 28, 2015 by Timesys Support
Good Day
I'm trying to integrate LCD  NHD-5.0-800480TF-ATXL into our system.
The display is now working. However due to hardware and physical location of the LCD I need to rotate the display 180 degrees.
I tried using updating files as mentioned in this discussionRotate the 3.5 inch LCD screen to 180 degree.
The result is it will only rotate the logo and when i run some GUI applications or display images it will revert back.
Any ideas what needs to be updated to successfully rotate the screen?
