I've got an FRDM-KL03Z which I would like to start in ROM bootloader mode.
Unfortunately, it seems to have an application in FLASH (I don't know/care what the app is).
I'm using Linux as my development host.
The OpenSDA docs talk about a flash programmer app, but it only runs under MS-Windows,
Eval boards for other vendors/parts always have had jumper(s) that forced the part's boot mode, but this board doesn't seem to have anything like that.
How do I erase flash so that it will boot up in the ROM bootloader?
Solved! Go to Solution.
Hi Grant,
You can use the following steps to force the MCU enter the ROM bootloader:
First of all, hold down the SW3 button, then reset the MCU and the MCU will enter the ROM bootloader.
Hope it helps.
Ping
Hi Grant,
Hope it helps.
Ping
