Current Consumption of MMA9553L?
wenxue
Hi Sir :
Customer: Beijing HTSmartech
The customer is now using our sensor MMA9553L. They are very cared about the current consumption. I searched all the documents and found the following results about current consumption:
MMA955xL.pdf
MMA9553LSWRN.pdf
I have a lot of doubts:
1) What's the meaning of "Supply current in RUN mode", does it mean the sensor in a moving state and it is calculating?
2) What factors influence the current consumption? And what measures customer can do to reduce the consumption of MMA9553L?
3) What's the meanig of "Inject"?
4) If the sensor are always in a moving state, what's the current consumption of it? And if is static, what's the consumption?
Any comments would be appreciated .
Wenxue
bryancole-b4682
wenxue, may I suggest moving this issue into the Sensors community? I think it will be supported more quickly there.
wenxue
OK , thanks
