Alignment trap: not handling instruction
Question asked by supriya negi on Apr 15, 2015
Latest reply on Apr 21, 2015 by supriya negi
HI all ,
Below I am trying to run some Bluetooth related scripts but getting below crash . How can I avoid this crash as it is produced randomly and not always.
rm: cannot remove `/var/run/dbus/pid': No such file or directory
BT FW is active(6)
Alignment trap: not handling instruction e19cef9f at [<c018b464>]
Unhandled fault: alignment exception (0x001) at 0x0000009d
Internal error: : 1 [#1] PREEMPT SMP
Modules linked in: bt8xxx
CPU: 0    Not tainted  (3.0.35-2508-g54750ff-ihmv7-svn430 #10)
PC is at dup_fd+0x13c/0x328
LR is at 0x0
pc : [<c018b468>]    lr : [<00000000>]    psr: 20000013
sp : da12def0  ip : 0000009d  fp : dfa12c00
r10: 00000007  r9 : 0000001b  r8 : 00000100
r7 : 00000100  r6 : df933fa0  r5 : 00000001  r4 : dfbb2874
r3 : 0000007d  r2 : 000000e4  r1 : 0000001c  r0 : dfa12c70
Flags: nzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment user
Control: 10c53c7d  Table: 2a0c804a  DAC: 00000015
Process BT_Init.sh (pid: 3273, stack limit = 0xda12c2f8)
Stack: (0xda12def0 to 0xda12e000)
dee0:                                     dffcbee0 dffcb820 01200011 dfee32c0
df00: 01200011 da12c000 00000000 c080a700 dfee33e4 000001c0 00000000 c00fb1a4
df20: 000010e9 00000000 00000000 dfee345c bed15818 da12dfb0 da1203c0 fffffff4
df40: 00000001 01200011 00000000 da12dfb0 00000000 bed15818 da12c000 00000000
df60: bed15834 c00fb95c 40076068 00000000 00000000 00000000 0000021c 00000000
df80: 00000000 00000000 00000001 00000000 40076068 00000000 40281000 00000078
dfa0: c00cc144 c00cbfc0 00000000 40076068 01200011 00000000 00000000 00000000
dfc0: 40076068 00000000 40281000 00000078 00000cc9 000abc48 000ac368 bed15834
dfe0: 400764c0 bed15818 00000000 401f1b48 60000010 01200011 00000000 00000000
[<c018b468>] (dup_fd+0x13c/0x328) from [<c00fb1a4>] (copy_process+0x5ec/0xce4)
[<c00fb1a4>] (copy_process+0x5ec/0xce4) from [<c00fb95c>] (do_fork+0x9c/0x264)
[<c00fb95c>] (do_fork+0x9c/0x264) from [<c00cbfc0>] (ret_fast_syscall+0x0/0x30)
Code: e3a01000 e58d5000 ea000009 e19cef9f (e28ee001)
---[ end trace 125b5a44c9432aed ]---
note: BT_Init.sh[3273] exited with preempt_count 1
BUG: scheduling while atomic: BT_Init.sh/3273/0x40000002
[<c00d2774>] (unwind_backtrace+0x0/0xf8) from [<c05bd654>] (__schedule+0x4c0/0x6c0)
[<c05bd654>] (__schedule+0x4c0/0x6c0) from [<c00f7bbc>] (__cond_resched+0x24/0x34)
[<c00f7bbc>] (__cond_resched+0x24/0x34) from [<c05bd8ec>] (_cond_resched+0x34/0x44)
[<c05bd8ec>] (_cond_resched+0x34/0x44) from [<c015b620>] (unmap_vmas+0x40c/0x670)
[<c015b620>] (unmap_vmas+0x40c/0x670) from [<c0160e38>] (exit_mmap+0x108/0x248)
[<c0160e38>] (exit_mmap+0x108/0x248) from [<c00fa508>] (mmput+0x48/0xf4)
[<c00fa508>] (mmput+0x48/0xf4) from [<c00fe510>] (exit_mm+0x128/0x168)
[<c00fe510>] (exit_mm+0x128/0x168) from [<c00ffe78>] (do_exit+0x570/0x6e8)
[<c00ffe78>] (do_exit+0x570/0x6e8) from [<c00cf73c>] (die+0x228/0x284)
[<c00cf73c>] (die+0x228/0x284) from [<c00c63dc>] (do_DataAbort+0x8c/0x9c)
[<c00c63dc>] (do_DataAbort+0x8c/0x9c) from [<c00cb990>] (__dabt_svc+0x70/0xa0)
Exception stack(0xda12dea8 to 0xda12def0)
dea0:                   dfa12c70 0000001c 000000e4 0000007d dfbb2874 00000001
dec0: df933fa0 00000100 00000100 0000001b 00000007 dfa12c00 0000009d da12def0
dee0: 00000000 c018b468 20000013 ffffffff
[<c00cb990>] (__dabt_svc+0x70/0xa0) from [<c018b468>] (dup_fd+0x13c/0x328)
./BT_Demo.sh: line 36:  3273 Segmentation fault      ./BT_Init.sh
