Downloading code to MCS08QE128 windowed area
Question asked by Tim Allen on Nov 14, 2007
Latest reply on Nov 16, 2007 by Tim Allen
Using the debugger in CW 6.1 Special Edition, I'm having difficulties downloading code to flash at $8000. I'm not currently using bank switching at all. Although CW reports programming at $8000, it appears to end up down around zero (through RAM!). Changing the start address to $4000 or $C000 works as expected.
The code to be programmed is in .S19 format, so I can clearly see the addresses in the file are correct.
Any help would be much appreciated - thanks.
