Sampling audio via UART (with PEx) with KL26Z64
Question asked by Gustavo Leal on Apr 12, 2015
Latest reply on Apr 13, 2015 by Gustavo Leal
Hi. I'm using a custom board with KL26Z64 and I'm trying to make a program that measures the ADC (to which a mic is connected) and sends the value via UART (serial) with a certain sample rate (in this case, 10kHz) indefinitely.
I want to capture audio to do some processing on a PC later.
I started a project with Processor Expert and added the ADC, Term (which uses AsynchroSerial) and TimerInt components. I set the timer interrupt period to 100us.
The baud rate is set to 38400 baud.
My ADC total conversion time is set to 11.68us and I'm running 3 conversions.
My code to do this task is as follows (on the timer interrupt event):
void TI1_OnInterrupt(void)
    AD1_Measure(TRUE);
    AD1_GetValue16(&leitura);
    Term1_SendNum(leitura);
    Term1_SendStr("\r\n");
As a result, I get the ADC values on my serial monitor. However, when I import these values to, say, MATLAB for processing, I see that the audio was not sampled at the correct rate.
What would be the most efficient way to do this?
Gustavo.
