How to record audio from on-board microphone on SABRE-SDB i.MX6sx
sublime
I have not been able to find any information in the freescale documentation for how to record audio from the built-in microphone on the SABRE-SDB board. I came across a webpage: How to use & access iMX6 peripherals (Examples) - iMX6 Rex Module and it showed examples of how to record from microphone;
# arecord -f dat -d 10 -D hw:0,0 test.wav
Play the recorded file:
# aplay -f dat test.wav
After booting the board I am able to record. However, when I playback, I do not hear anything coming out of my headset. I am booting for the SD card image that came with the board.
Javier
P.S. Where is the test.wav file stored?
Labels (2)
sinanakman
Senior Contributor III
Hi Javier
Did you try this :
amixer sset 'INPGAR IN3R' on
Sinan Akman
Yuri
Please check if a capture device (MIC) is present in configuration,
using the command :
/$ arecord -l
Perhaps the problem concerns with the improper volume controls for input / output
sound channels. Please use "amixer" or "alsamixer" utilities to amplify sound data
Please use amixer help for some details :
$ amixer --h
Note, alsamixer uses pseudographic interface.
Yuri
sublime
YuriMuhin_ng
sinanakman
Thanks for your help. I am able to record now and playback.
sublime
Hi Yuri, Hi sinanakman
Please see my terminal output below. I am having difficulty turning on headphone output:
root@imx6sxsabresd:~# amixer sget 'HPOUTR PGA' on
Simple mixer control 'HPOUTR PGA',0
  Capabilities: enum
  Items: 'DAC' 'Mixer'
  Item0: 'DAC'
root@imx6sxsabresd:~# amixer sset 'HPOUTR PGA' on
amixer: Invalid command!
sublime
I typed alsamixer and a GUI appeared. I noticed "INPGAR IN3R" is disabled. How can I enable this pin?
The SABRE-SDB schematic shows microphone input as IN3R.
WM8962 Codec
sinanakman
Hi Javier
Did you try this :
Sinan Akman
sublime
Hi Sinan,
Thanks for your help. It is turned on now. However, I am still not able to playback.
