P4080DS How to get details of MAC counters
sharathchandra
I am trying to figure out Tx packet loss on P4080DS board, though DPA or BMI counters does not show any loss in Tx frames, I find some Tx packets are lost.
I think it is not dropped/lost in FMAN or BMAN or QMAN, so probably at MAC, they are lost. How and where should I check for the MAC registers/counters for errors/status on my system?
Sharath Chandra
alexander_yakov
What is your test setup - which tool is used to detect packet loss?
sharathchandra
Hi Alexander,
On P4080DS system with all the images loaded from SDK v1.7, I tried to run a sample UDP sender which sends packet out of the board to another destination.
I was using fm1-gb1 interface on the board.
I was running wireshark on the other system, which would capture the packets sent from the board. I see some packets missing.
Even I tried to take a tcpdump on the board, which also showed the same info as that of wireshark on other system. As per this, I felt it is inside the board itself where the packets are lost. I was able to check BMI and DPA counters and they show nothing. Even ifconfig does not show any tx errors/drops.
Probably assuming they are dropped at MAC or somewhere? I dont know how to check MAC counters but.
Sharath Chandra
alexander_yakov
I do not think wireshark is absolutely precise. Please try testing in loopback mode.
