no task to run
no task to run
ava
Hello Everyone,
I am using MK60FX512VLQ12 controller, CW10.6 & MQX4.1.
In my project I am using different task as main,usb,can,gprs,sd card & its working fine.
But recently I have observed sometimes my system get hang after restarting it works fine, then I debug the code and come to know that it goes to dispatch.s where its written no task to run and in MQX task summary status for all tasks is OK  & it is in time delay loop.
Then why I am getting no task to run?
How to solve this problem?
Please help me.
Thanks.
ivadorazinova
Dear T tech,
it could be problem with your stack size.
Please,check these threads if is not the same problem like you have
Re: MQX on custom board stuck in dispatch.s
Debug stuck in dispatch.s with MQX 4.1
If does not help, we find another solution.
Iva
ava
Hi Iva,
Thanks for your reply I will go through these post.
I am trying by modifying the stack size for the tasks.
Thanks.
