Hello
Is the a way to change the temp dirs. KDS 2.0 uses. I keep getting the following error: process_begin: (C:\Users\JAMES~1.NAD\AppData\Local\Temp\make8812-1.bat, ...) failed
make (e=5): Access is denied.
There are a lot of polices applied to these machines. I think they re-map the temp dirs. and that causes problems with some applications. I wanted to try changing the directory to something I know I can access.
Thanks Jay
I changed my user environment vars tmp and temp to a directory I had access to and it is working again.
