How to change DRAM(DDR3) clock freq of imx6dl_sabresd?
Question asked by jiang shao on Apr 8, 2015
Latest reply on Apr 8, 2015 by Yuri Muhin
I have a custom imx6dl_sabresd board with 2GB RAM.
Sometimes it will reset when play the 1080p videos.
I want to know how to change DRAM(DDR3) clock freq of imx6dl_sabresd?
Such as 400MHz->333MHz.
And this is the flash_header.S which I am using.
#else /* i.MX6DL 64BIT-DDR */
dcd_hdr:          .word 0x40A002D2 /* Tag=0xD2, Len=83*8 + 4 + 4, Ver=0x40 */
write_dcd_cmd:    .word 0x049C02CC /* Tag=0xCC, Len=83*8 + 4, Param=0x04 */
# IOMUXC_BASE_ADDR  = 0x20e0000
# DDR IO TYPE
MXC_DCD_ITEM(1, IOMUXC_BASE_ADDR + 0x774, 0x000c0000)
MXC_DCD_ITEM(2, IOMUXC_BASE_ADDR + 0x754, 0x00000000)
# Clock
MXC_DCD_ITEM(3, IOMUXC_BASE_ADDR + 0x4ac, 0x00000028)
MXC_DCD_ITEM(4, IOMUXC_BASE_ADDR + 0x4b0, 0x00000028)
# Address
MXC_DCD_ITEM(5, IOMUXC_BASE_ADDR + 0x464, 0x00000028)
MXC_DCD_ITEM(6, IOMUXC_BASE_ADDR + 0x490, 0x00000028)
MXC_DCD_ITEM(7, IOMUXC_BASE_ADDR + 0x74c, 0x00000028)
# Control
MXC_DCD_ITEM(8, IOMUXC_BASE_ADDR + 0x494, 0x00000028)
MXC_DCD_ITEM(9, IOMUXC_BASE_ADDR + 0x4a0, 0x00000000)
MXC_DCD_ITEM(10, IOMUXC_BASE_ADDR + 0x4b4, 0x00000028)
MXC_DCD_ITEM(11, IOMUXC_BASE_ADDR + 0x4b8, 0x00000028)
MXC_DCD_ITEM(12, IOMUXC_BASE_ADDR + 0x76c, 0x00000028)
# Data Strobe
MXC_DCD_ITEM(13, IOMUXC_BASE_ADDR + 0x750, 0x00020000)
MXC_DCD_ITEM(14, IOMUXC_BASE_ADDR + 0x4bc, 0x00000028)
MXC_DCD_ITEM(15, IOMUXC_BASE_ADDR + 0x4c0, 0x00000028)
MXC_DCD_ITEM(16, IOMUXC_BASE_ADDR + 0x4c4, 0x00000028)
MXC_DCD_ITEM(17, IOMUXC_BASE_ADDR + 0x4c8, 0x00000028)
MXC_DCD_ITEM(18, IOMUXC_BASE_ADDR + 0x4cc, 0x00000028)
MXC_DCD_ITEM(19, IOMUXC_BASE_ADDR + 0x4d0, 0x00000028)
MXC_DCD_ITEM(20, IOMUXC_BASE_ADDR + 0x4d4, 0x00000028)
MXC_DCD_ITEM(21, IOMUXC_BASE_ADDR + 0x4d8, 0x00000028)
MXC_DCD_ITEM(22, IOMUXC_BASE_ADDR + 0x760, 0x00020000)
MXC_DCD_ITEM(23, IOMUXC_BASE_ADDR + 0x764, 0x00000028)
MXC_DCD_ITEM(24, IOMUXC_BASE_ADDR + 0x770, 0x00000028)
MXC_DCD_ITEM(25, IOMUXC_BASE_ADDR + 0x778, 0x00000028)
MXC_DCD_ITEM(26, IOMUXC_BASE_ADDR + 0x77c, 0x00000028)
MXC_DCD_ITEM(27, IOMUXC_BASE_ADDR + 0x780, 0x00000028)
MXC_DCD_ITEM(28, IOMUXC_BASE_ADDR + 0x784, 0x00000028)
MXC_DCD_ITEM(29, IOMUXC_BASE_ADDR + 0x78c, 0x00000028)
MXC_DCD_ITEM(30, IOMUXC_BASE_ADDR + 0x748, 0x00000028)
MXC_DCD_ITEM(31, IOMUXC_BASE_ADDR + 0x470, 0x00000028)
MXC_DCD_ITEM(32, IOMUXC_BASE_ADDR + 0x474, 0x00000028)
MXC_DCD_ITEM(33, IOMUXC_BASE_ADDR + 0x478, 0x00000028)
MXC_DCD_ITEM(34, IOMUXC_BASE_ADDR + 0x47c, 0x00000028)
MXC_DCD_ITEM(35, IOMUXC_BASE_ADDR + 0x480, 0x00000028)
MXC_DCD_ITEM(36, IOMUXC_BASE_ADDR + 0x484, 0x00000028)
MXC_DCD_ITEM(37, IOMUXC_BASE_ADDR + 0x488, 0x00000028)
MXC_DCD_ITEM(38, IOMUXC_BASE_ADDR + 0x48c, 0x00000028)
# MMDC_P0_BASE_ADDR = 0x021b0000
# MMDC_P1_BASE_ADDR = 0x021b4000
# Calibrations
# ZQ
MXC_DCD_ITEM(39, MMDC_P0_BASE_ADDR + 0x800, 0xa1390003)
# write leveling
MXC_DCD_ITEM(40, MMDC_P0_BASE_ADDR + 0x80c, 0x001F001F)
MXC_DCD_ITEM(41, MMDC_P0_BASE_ADDR + 0x810, 0x001F001F)
MXC_DCD_ITEM(42, MMDC_P1_BASE_ADDR + 0x80c, 0x001F001F)
MXC_DCD_ITEM(43, MMDC_P1_BASE_ADDR + 0x810, 0x001F001F)
# DQS gating, read delay, write delay calibration values
# based on calibration compare of 0x00ffff00
# change by shao, 2015-04-07 begin
# MXC_DCD_ITEM(44, MMDC_P0_BASE_ADDR + 0x83c, 0x42480248)
# MXC_DCD_ITEM(45, MMDC_P0_BASE_ADDR + 0x840, 0x0211020B)
# MXC_DCD_ITEM(46, MMDC_P1_BASE_ADDR + 0x83C, 0x417F0211)
# MXC_DCD_ITEM(47, MMDC_P1_BASE_ADDR + 0x840, 0x015D0166)
# MXC_DCD_ITEM(48, MMDC_P0_BASE_ADDR + 0x848, 0x4B4C504D)
# MXC_DCD_ITEM(49, MMDC_P1_BASE_ADDR + 0x848, 0x494C4F48)
# MXC_DCD_ITEM(50, MMDC_P0_BASE_ADDR + 0x850, 0x3F3F2E31)
# MXC_DCD_ITEM(51, MMDC_P1_BASE_ADDR + 0x850, 0x2B35382B)
MXC_DCD_ITEM(44, MMDC_P0_BASE_ADDR + 0x83c, 0x02700268)
MXC_DCD_ITEM(45, MMDC_P0_BASE_ADDR + 0x840, 0x02600260)
MXC_DCD_ITEM(46, MMDC_P1_BASE_ADDR + 0x83C, 0x0258025C)
MXC_DCD_ITEM(47, MMDC_P1_BASE_ADDR + 0x840, 0x023C024C)
MXC_DCD_ITEM(48, MMDC_P0_BASE_ADDR + 0x848, 0x48464C4A)
MXC_DCD_ITEM(49, MMDC_P1_BASE_ADDR + 0x848, 0x484E4C48)
MXC_DCD_ITEM(50, MMDC_P0_BASE_ADDR + 0x850, 0x36342C34)
MXC_DCD_ITEM(51, MMDC_P1_BASE_ADDR + 0x850, 0x36323628)
# change by shao, 2015-04-07 end
MXC_DCD_ITEM(52, MMDC_P0_BASE_ADDR + 0x81c, 0x33333333)
MXC_DCD_ITEM(53, MMDC_P0_BASE_ADDR + 0x820, 0x33333333)
MXC_DCD_ITEM(54, MMDC_P0_BASE_ADDR + 0x824, 0x33333333)
MXC_DCD_ITEM(55, MMDC_P0_BASE_ADDR + 0x828, 0x33333333)
MXC_DCD_ITEM(56, MMDC_P1_BASE_ADDR + 0x81c, 0x33333333)
MXC_DCD_ITEM(57, MMDC_P1_BASE_ADDR + 0x820, 0x33333333)
MXC_DCD_ITEM(58, MMDC_P1_BASE_ADDR + 0x824, 0x33333333)
MXC_DCD_ITEM(59, MMDC_P1_BASE_ADDR + 0x828, 0x33333333)
MXC_DCD_ITEM(60, MMDC_P0_BASE_ADDR + 0x8b8, 0x00000800)
MXC_DCD_ITEM(61, MMDC_P1_BASE_ADDR + 0x8b8, 0x00000800)
# MMDC init:
# in DDR3, 64-bit mode, only MMDC0 is initiated:
MXC_DCD_ITEM(62, MMDC_P0_BASE_ADDR + 0x004, 0x0002002D)
MXC_DCD_ITEM(63, MMDC_P0_BASE_ADDR + 0x008, 0x00333040)
MXC_DCD_ITEM(64, MMDC_P0_BASE_ADDR + 0x00c, 0x676B52F3)
MXC_DCD_ITEM(65, MMDC_P0_BASE_ADDR + 0x010, 0xB66D8B63)
MXC_DCD_ITEM(66, MMDC_P0_BASE_ADDR + 0x014, 0x01FF00DB)
MXC_DCD_ITEM(67, MMDC_P0_BASE_ADDR + 0x018, 0x00011740)
MXC_DCD_ITEM(68, MMDC_P0_BASE_ADDR + 0x01c, 0x00008000)
MXC_DCD_ITEM(69, MMDC_P0_BASE_ADDR + 0x02c, 0x000026d2)
MXC_DCD_ITEM(70, MMDC_P0_BASE_ADDR + 0x030, 0x006B1023)
MXC_DCD_ITEM(71, MMDC_P0_BASE_ADDR + 0x040, 0x00000047)
MXC_DCD_ITEM(72, MMDC_P0_BASE_ADDR + 0x000, 0x841A0000)
# Initialize 2GB DDR3 - Micron MT41J128M
MXC_DCD_ITEM(73, MMDC_P0_BASE_ADDR + 0x01c, 0x02008032)
MXC_DCD_ITEM(74, MMDC_P0_BASE_ADDR + 0x01c, 0x00008033)
MXC_DCD_ITEM(75, MMDC_P0_BASE_ADDR + 0x01c, 0x00048031)
MXC_DCD_ITEM(76, MMDC_P0_BASE_ADDR + 0x01c, 0x15208030)
MXC_DCD_ITEM(77, MMDC_P0_BASE_ADDR + 0x01c, 0x04008040)
MXC_DCD_ITEM(78, MMDC_P0_BASE_ADDR + 0x020, 0x00007800)
MXC_DCD_ITEM(79, MMDC_P0_BASE_ADDR + 0x818, 0x00022227)
MXC_DCD_ITEM(80, MMDC_P1_BASE_ADDR + 0x818, 0x00022227)
MXC_DCD_ITEM(81, MMDC_P0_BASE_ADDR + 0x004, 0x0002556d)
MXC_DCD_ITEM(82, MMDC_P1_BASE_ADDR + 0x404, 0x00011006)
MXC_DCD_ITEM(83, MMDC_P0_BASE_ADDR + 0x01c, 0x00000000)
#endif
