Init_I2S error messages
Question asked by Josh Jordan on Apr 6, 2015
Latest reply on Apr 7, 2015 by Alice_Yang
I get errors when I try to use the I2S master clock in the Init_I2S bean.  When I set the serial master clock pin I get this error :
DescriptionResourcePathLocationType
Direction Output cannot be set. Supported directions are: [Input/Output] (Pin)Main_K22I2S0/PinProcessor Expert Problem
I've tried changing that pin to the other available master clock pin and get the same error.  If I make it an input instead of an output I get a similar error that "Direction Input cannot be set."
