Gstreamer videomixer can't negotiate format and missing video/x-raw-yuv
Question asked by Nathan Mak on Apr 3, 2015
Latest reply on Apr 10, 2015 by Nathan Mak
Leonardo Sandoval Gonzalez
Problem 1: videomixer can't negotiate format
Using an ADV7180 connected to CSI0/IPU1 the following command works great
gst-launch -v tvsrc device=/dev/video0 typefind=true ! mfw_ipucsc ! videocrop ! mfw_v4lsink  device=/dev/video17
Using a usb video source the following command works great
gst-launch v4l2src device=/dev/video2 ! mfw_v4lsink device=/dev/video17
The following command has problems
gst-launch -v \
tvsrc device=/dev/video0 typefind=true ! mfw_ipucsc ! videocrop \
! videomixer name=mix ! mfw_v4lsink sync=false \
v4l2src device=/dev/video2 \
! mix.
ouput log
root@varsomimx6q:~# gst-launch -v \
> ! mix.
MFW_GST_tvsrc_PLUGIN 3.0.9 build on Sep  5 2014 14:41:24.
IPU_CSC_CORE_LIBRARY_VERSION_INFOR_01.00.
MFW_GST_IPU_CSC_PLUGIN 3.0.9 build on Sep  5 2014 14:42:37.
MFW_GST_V4LSINK_PLUGIN 3.0.9 build on Sep  5 2014 14:40:39.
Setting pipeline to PAUSED ...
/GstPipeline:pipeline0/GstV4l2Src  device name=Mxc Camera type=1:v4l2src0.GstPad:src: caps = video/x-raw-yuv, format=(fourcc)YUY2,
framerate=(fraction)30000/1001, width=(int)720, height=(int)480,
interlaced=(boolean)true, pixel-aspect-ratio=(fraction)1/1
sensor chip is adv7180_decoder
/GstPipeline:pipeline0/MFWGstTVSRC:mfwgsttvsrc0.GstPad:src: caps = video/x-raw-yuv, framerate=(fraction)30/1, format=(fourcc)NV12, width=(int)720, height=(int)48[70696.582030] imx-ipuv3 2400000.ipu: IPU Warning - IPU_INT_STAT_5 = 0x00000001
0, pixel-aspect-ratio=(fraction)1/1
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
/GstPipeline:pipeline0/GstVideoMixer:mix.GstVideoMixerPad:sink_0: caps = video/x-raw-yuv, format=(fourcc)YUY2, framerate=(fraction)30000/1001, width=(int)720, height=(int)480, interlaced=(boolean)true, pixel-aspect-ratio=(fraction)1/1
/GstPipeline:pipeline0/MFWGstTVSRC:mfwgsttvsrc0.GstPad:src: caps = video/x-raw-yuv, framerate=(fraction)30/1, format=(fourcc)NV12, width=(int)720, height=(int)480, pixel-aspect-ratio=(fraction)1/1, field=(int)2
ERROR: from element /GstPipeline:pipeline0/MFWGstTVSRC:mfwgsttvsrc0: Internal data flow error.
Additional debug info:
/data/cat2700/build/var-som-mx6-dora-v5/build_mx6q/tmp/work/cortexa9hf-vfp-neon-poky-linux-gnueabi/gstreamer/0.10.36-r2/gstreamer-0.10.36/libs/gst/base/gstbasesrc.c(2625): gst_base_src_loop (): /GstPipeline:pipeline0/MFWGstTVSRC:mfwgsttvsrc0:
streaming task paused, reason not-negotiated (-4)
Execution ended after 43930000 ns.
/GstPipeline:pipeline0/GstVideoMixer:mix.GstPad:src: caps = video/x-raw-yuv, format=(fourcc)YUY2, framerate=(fraction)30000/1001, width=(int)720, height=(int)480, interlaced=(boolean)true, pixel-aspect-ratio=(fraction)1/1
Setting pipeline to READY ...
set v4l rotate sucessfully
>>V4L_SINK: Actually buffer status:
        hardware buffer : 12
        software buffer : 0
/GstPipeline:pipeline0/GstVideoMixer:mix.GstVideoMixerPad:sink_0: caps = NULL
/GstPipeline:pipeline0/GstVideoMixer:mix.GstPad:src: caps = NULL
/GstPipeline:pipeline0/GstV4l2Src:v4l2src0.GstPad:src: caps = NULL
/GstPipeline:pipeline0/MFWGstTVSRC:mfwgsttvsrc0.GstPad:src: caps = NULL
Setting pipeline to NULL ...
Total rendered:0
Freeing pipeline ...
[--->FINALIZE v4l_sink
I'm not sure what the bit about filter caps is.
Problem 2:
Running something bellow with video/x-raw-yuv also doesn't work
gst-launch-0.10 -v \
tvsrc device=/dev/video0 \
! video/x-raw-yuv, framerate=30/1, width=720, height=480 \
! videomixer name=mix ! mfw_ipucsc ! videocrop ! mfw_v4lsink sync=false \
tvsrc device=/dev/video2 \
! mix.
I also get
root@varsomimx6q:~# gst-inspect video/x-raw-yuv
No such element or plugin 'video/x-raw-yuv'
Am I missing a plugin  or is that how it just works?
