NULL POINTER DEREFERENCE USB 5.0 STACK
Question asked by John Strohm on Apr 3, 2015
Latest reply on Apr 6, 2015 by Jorge_Gonzalez
In file usb_dev.c, routine _usb_device_call_service_internal(), which starts at line 231:
On line 239, service_ptr is set to NULL.
    service_struct_t*             service_ptr = NULL;   // line 239
service_ptr is then dereferenced, on lines 248, 251, 255, 258, and 263.
            USB_Control_Service(&usb_dev_ptr->usb_framework, event, service_ptr->arg);  // line 248
            USB_Reset_Service(&usb_dev_ptr->usb_framework, event, service_ptr->arg);    // line 251
            USB_Suspend_Service(&usb_dev_ptr->usb_framework, event, service_ptr->arg);  // line 255
            USB_Resume_Service(&usb_dev_ptr->usb_framework, event, service_ptr->arg);   // line 258
            USB_Error_Service(&usb_dev_ptr->usb_framework, event, service_ptr->arg);    // line 263
You get away with it because Freescale processors traditionally have readable (usually read-only) memory starting at address 0x00000000, so the hardware doesn't trap those accesses.
This is really a bad idea, guys.
