how to get the root permission in android-4.3(imx6q_sabresd)
Question asked by wang zhigang on Apr 2, 2015
hi everyone,
    I want to execute the command("blkid > filename") in my android-4.3 system ,and the platform is imx6q_sabresd,but I failed to execute the command,because I have not the root permission.so I attempted to root my android-4.3 system as follow:
1.su.c
int main(int argc, char *argv[])
    ALOGI("hello !robin-su begin %d !",getuid());
    printf("hello !robin-su begin");
  int uid=0;
  int gid=0;
  if(setgid(gid) || setuid(uid)) {
  ALOGI("robin su: permission denied\n");
  fprintf(stderr,"su: permission denied\n");
  return 1;
  char command[1024];
    ALOGI("hello !robin-su end %d !",getuid());
    printf("hello !robin-su end");
  /* Default exec shell. */
  execlp("/system/bin/sh", "sh", NULL);
  fprintf(stderr, "su: exec failed\n");
    return 1;
2.su.h
3.Android.mk
LOCAL_PATH := $(call my-dir)
include $(CLEAR_VARS)
LOCAL_MODULE := su
LOCAL_SRC_FILES := su.c
LOCAL_STATIC_LIBRARIES := \
    liblog \
    libc \
LOCAL_MODULE_PATH := $(TARGET_OUT_OPTIONAL_EXECUTABLES)
LOCAL_MODULE_TAGS := eng debug
LOCAL_FORCE_STATIC_EXECUTABLE := true
include $(BUILD_EXECUTABLE)
3.compile the su file
$ mkdir -p packages/experimental/su
$ cp su.c su.h Android.mk  packages/experimental/su
$ mmm packages/experimental/su
4.apk (MainActivity.java)
try{
  process = Runtime.getRuntime().exec("/system/xbin/su");
  os = new DataOutputStream(process.getOutputStream());
  os.writeBytes("blkid > /data/local/tmp/label" + "\n");
  os.writeBytes("exit\n");
  os.flush();
  process.waitFor();
} catch (Exception e){
  Log.e(LOG_TAG, "===unexpected error===");
}finally {
  try {
  if(os != null){
  os.close();
  process.destroy();
  }catch (Exception e){
5.apk(Android.mk)
LOCAL_PATH:= $(call my-dir)
LOCAL_MODULE_TAGS := optional
# Only compile source java files in this apk.
LOCAL_SRC_FILES := $(call all-java-files-under, src)
LOCAL_PACKAGE_NAME := usb_label
include $(BUILD_PACKAGE)
6.compile apk
$ mkdir -p packages/experimental/usb_label
$ cp su.c su.h Android.mk  packages/experimental/usb_label
$ mmm packages/experimental/usb_label
7.compile android-4.3
source build/envsetup.sh
lunch sabresd_6dq-user
make -j8
8.write sd card
dd if=system.img of=/dev/mmcblk0p5;sync
9.start android system
$ mount -o remount,rw /system
$ chmod 4755 system/xbin/su
reboot system again
10.run apk
I failed to execute the the command("blkid > filename"),and get the log:
1)
W/AudioPolicyManagerBase( 2489): getOutput() could not find output for stream 1, samplingRate 0,format 0, channels 3, flags 0
W/AudioPolicyManagerBase( 2489): getOutput() could not find output for stream 1, samplingRate 48000,format 1, channels 1, flags 4
2)
11.replace the su file
I found that if I compile the android-4.3 in "eng" mode,the is a "su" file in system/xbin/su,so I replace the new su file into my android-4.3(user mode),and test again.I still failed to get the root permission.and get the same log:
Is everyone can help me?
Best wishes!
